C4 to 3sp Conversion
DenverEB
Post by DenverEB »
I'm swaping out my c4 for a 3sp manual (302). Before I buy all new parts, I wanted to see if anyone has these laying around.
Clutch assembly (flywheel, pressure plate, clutch disc, pilot bushing and throwout bearing)
clutch linkage
clutch fork
manual bell housing
engine block plate for manual transmission
adapter to Dana 20
Thanks,
Ryan
Re: C4 to 3sp Conversion
Post by Kinder »
IΓÇÖve got the bell, fork & linkage, I likely have some other small parts as well.
BOBS 2 68S
Post by BOBS 2 68S »
I have an adapter 3 speed manual to dana 20
D&D72
Post by D&D72 »
Are you putting it back on the column? I might have those linkages.
DenverEB
Post by DenverEB »
I'm putting it on the floor. Thanks though.
Post by landshark »
What are doing with the c4? [emoji3]
Friday
VENDOR
VENDOR
Post by Friday »
I have everthing you need as I went the other way-3 speed to c4. Installed but zero miles: New clutch and resurfaced flywheel, floor conversions stuff as well. Bellhouseing clutch fork etc...Do you need a column?
DenverEB
Post by DenverEB »
PM sent
