2.5" Suspension System - Which would you choose?
phyler
CCB Admin
Post by phyler »
I know this has been beat to death. All the systems are pretty close to each other so it usually comes down to shipping. That said, I have a few questions that I'd like to get input on.
First, my existing suspension is old K Bar S (yes, seriously, I was so excited when I ordered/installed these in 1994) 2" front coils. They have not sagged at all. I can tell which side of a quarter is up when I roll over it. The rear is a 2" (or 2.5") springs from National with a 1" block. The shocks are old Rancho 5000's from the late 90's. No matter which suspension I go to, it will be a massive difference. I earned some extra money on a side job so the wife is encouraging me to upgrade the suspension before dropping money on the engine/tranny that I have sitting here because it will make her more inclined to ride with me which would be nice.
So, I want a 2.5" system with a new adjustable trac bar (still running the stock one with no drop bracket or riser). The choice is between Wild Horses and Duff's. If I go with Duff's, it would probably be to go with the T-Rex arms as an added bonus. I am thinking I will do the F-250 shock towers. Thinking just the 70/30 shocks or Bilstien's (the Eibach's from Duff's look super nice but would put me over what I'm comfortable spending right now). This is predominantly a street cruiser and mild off-roader. The biggest thing I would like to achieve is not feeling like the entire thing will fall apart trying to crawl down a washboard road.
I have a 1" body lift already so don't want to go too much higher. So, would you go Duff's with the T-Rex arms or save some money and just do a Wild Horses kit? I've heard the Duff's springs are Deaver's and are a little softer but not 100% on that.
So what say you? Need to get it ordered if I want it installed by Super Cel. I know i could just wait til then and save the shipping but that would take some of the fun out of Super Cel as the wife would not want to go on rides with how stiff the Bronco is currently.
OG
Re: 2.5" Suspension System - Which would you choose?
Post by Eck »
IΓÇÖve got the WH lift with Bilstein 5100ΓÇÖs, F250 shock towers and Lars Bars long radius arms. YouΓÇÖre welcome to take a ride if you want to see how it feels.
phyler
CCB Admin
Post by phyler »
Eck wrote:IΓÇÖve got the WH lift with Bilstein 5100ΓÇÖs, F250 shock towers and Lars Bars long radius arms. YouΓÇÖre welcome to take a ride if you want to see how it feels.
Sounds good. I'll figure out a way to ditch the kids and bring Mandy along so she can feel the diff as well. Or just cause she likes hanging with your wife.
OG
Post by Rox Crusher »
I think Duff's is the way to go for suspension and I really think those T-rex arms are a great choice for a rig with 2.5" lift.
When I did my Duff long arms last year I went with their Eibachs and new towers which were super easy to install.
https://dufftuff.com/product/universal- ... ock-tower/
TOOLMAN
Post by TOOLMAN »
I did Duff's HD 3.5" in the rear and WH 3.5 in front with Bilstein 5125 255/70 (rear) and 7100 (360/80) in the front. I also did Duff long arms and towers up front as well like Jeff did.
phyler
CCB Admin
Post by phyler »
TOOLMAN wrote:I did Duff's HD 3.5" in the rear and WH 3.5 in front with Bilstein 5125 255/70 (rear) and 7100 (360/80) in the front. I also did Duff long arms and towers up front as well like Jeff did.
Riding with you at Super Cel opened my eyes to how bad the ride in mine really is. Definitely want the towers in the front for the longer shock. Not wanting to go long arm if I can avoid it.
OG
Post by Eck »
For what it is worth-- I have been seeing where the Duff suspension kits are on major backorder. If you are really wanting to have it done for SuperCel-- I would get on it soon and definitely phone your order in wherever you end up getting the stuff.
Post by landshark »
What are you gaining with the duff trex arms? They are stock length correct? I would put my money into springs and shocks, deavers all around, coils can be bought from JeffΓÇÖs bronco graveyard (if they still carry them), rears from duff. Bilsteins 5150ΓÇÖs all around, adjustable track bar and probably have to have a drop pitman arm or small riser on the axle. 7 degree wedges on radius arms with all new bushings.
The deavers are slightly softer but the ride quality slightly better than anything else out there that you can buy off the shelf.
I had the above on my 76 with a 2.5ΓÇ¥ lift and 1ΓÇ¥ body lift and it road fantastic. I probably wouldnΓÇÖt even mess with the f250 shock towers as the longer shock wonΓÇÖt net you much with a 2.5ΓÇ¥ lift, but itΓÇÖs a easy swap :)
phyler
CCB Admin
Post by phyler »
landshark wrote:What are you gaining with the duff trex arms? They are stock length correct? I would put my money into springs and shocks, deavers all around, coils can be bought from JeffΓÇÖs bronco graveyard (if they still carry them), rears from duff. Bilsteins 5150ΓÇÖs all around, adjustable track bar and probably have to have a drop pitman arm or small riser on the axle. 7 degree wedges on radius arms with all new bushings.
Biggest two reasons for the T-Rex arms is the built in caster and the bend to allow tires to turn more before hitting the arm.
I'll look at Jeff's but I've just never had a good experience with them.
OG
If I were making that call I'd go with Duff or WH lift, then long arms down the road. Not sure I'd mess with the T-rex arms. The flatter angle of the arm will make a difference in the ride and it's an easy install. I'd put the money from the arms into Eibach or Bilstein shocks.
phyler
CCB Admin
Post by phyler »
Well, after texting with Landshark, I looked back and found my receipt from 1994 and the K Bar S catalog and realized my front springs were 4.5". Measured and I'm at 3.25 of lift in the front and 3.5" in the rear.
Going to go with the 3.5" lift to try and keep things the same. The good part is that those parts are in stock vs the 2.5".
Will get new springs, shocks, bushings and track bar. Then will go from there. ImageImage
OG
