4x4x2 donor box list
Post by Gunnibronco »
Does anyone have the list of donor "x2" boxes for the 4x4x2 swap?
West Coast Broncos web site has been down, and they had the best list of options.
I am thinking of putting together another one and porting it before installation. I have the 78/79 box, just need the reverse worm gear.
Re: 4x4x2 donor box list
Post by Viperwolf1 »
Just about anything other than a 78-79 Bronco/F150 that uses the Ford box will have the standard rotation you are looking for.
Viperwolf1 wrote:Just about anything other than a 78-79 Bronco/F150 that uses the Ford box will have the standard rotation you are looking for.
Thanks, I forget what I used. I think it was an Explorer box, but I can't remember the year. I saved about everything else from the WCB web site, except the list of donor boxes.
I'm considering having it rebuilt/add bearing & ported by one of the go-to companies. One quoted me an extra $50 to add the reverse worm drive. It's probably less than buying one, unless I go get it at a pick-n-pull myself.
pgilbeau
Post by pgilbeau »
Just checked my stuff and looks like I did the same, saved manual but not the list. I used a 90's 2wd Explorer/Ranger box.
Thanks for looking.
I think the WCB site is down due to Ford litigation about the Bronco name.
Post by Kinder »
SomeoneΓÇÖs ears must have been burning on CB.com
http://cloud.tapatalk.com/s/61279f958fee0/4x4x2%20instructions.pdf
pgilbeau
Post by pgilbeau »
Kinder wrote:SomeoneΓÇÖs ears must have been burning on CB.com
Awesome! Glad you saved that.
Thanks for the heads up. Downloaded and saved.
