I know it's a long shot but I'm selling the axles removed from my Bronco both ran great and quiet, removed to upgrade. I'm putting this stuff up here before torturing myself with a FB Marketplace or Craigslist ad. Let me know if you are interested, I'll make a good deal on a package deal. I'll ship the smaller items for the cost of UPS, USPS, etc.
Located in Gardnerville, NV. With payment I will hold until Carson City NV Bronco Super Celebration.
1979 F150/Bronco axles. $1,200.00 for the set
Front: HPD44 3.50 gears, open, newer wheel bearings, axle seals, brakes(slotted & drill rotors) with T-bird calipers and stainless soft lines, axle u-joints and ball joints, Mile Marker Premium locking hubs, 1310 yoke, 66"wms- probably needs a pinion seal.
Rear: 9", 3.50 gears, Lock Rite, 31 spline axles, newer Set20 wheel bearings and seals and drum brakes, 1310 Yukon yoke, 65.5" wms. Shock mounts and spring perches will probably need replaced/moved for your application. Some oil seeping through carrier to housing seal.
2 ea 76/77 HPD44 housings and axle shafts (no knuckles), probably 3.50 open gears, 1310 yokes. These are the housings with thicker wall tube and welded on radius arm wedges. $150 each
D44 carrier for 4.11 and up gears. Make offer/will throw in with the axle set.
D44 Lock Rite locker- purchased used, never ran myself, looks good. Make offer/will throw in with axle set.
9" drop out with 4.56 gears & Lock Rite- set up for 28 spline axles but could easily be changed to 31 spline axles. Purchased from CCB member, never ran myself. $400.00
Currie CE-6012 - spacer ring set for Explorer rear brakes- new never installed $30
1996 F350 D60 parts-
Stock axles (inner and outer)- Full set $200
Stock lock out hubs- 2 sets - 1 Warn, 1 Ford. Recently disassembled, cleaned and greased. Good condition $50/pr
Dana Spicer Lifetime SPL55-3x -1480 axle ujoints- 2ea -installed and removed, never ran $25ea
Dana Spicer 700238-2x ball joints- 2 sets- installed and removed, never ran. $40/set
14 Bolt parts
SRW hubs for 89+ "short spindle" housings/slip over brake drums. 8x6.5 pattern, metric wheel studs. Used very good condition - $50/pr
Lugnut 4x4 brake caliper brackets for slip over brake drums. New, never installed. $40
AC Delco brake rotor for Lugnut 4x4 brake brackets. New, never installed. $50/pr
79 F150/Bronco axles, misc D44, 9", D60, 14B parts
- Gunnibronco
- Jesus_man
Re: 79 F150/Bronco axles, misc D44, 9", D60, 14B parts
https://www.goldcountrybroncos.com/community/index.php - List these in their forum too!
- Gunnibronco
Good idea. I didn't know they had a forum set up I was only aware of the FB site.
