Pray for me.....
- airbur
Pray for me.....
Weekend project....
- akaFrankCastle
Re: Pray for me.....
Green scotchbrite pads should soon be your friend. Enjoy.
- goldenboy_cp
- cobshane
What is that a fusion transfunctioner
B.O.B.
Let me know when you are done and I will help you with the flux capacitor and Mr. fusion install
- airbur
Haha....thanks guys. I got the whole thing apart last night but I could only fit half of the carb in the cleaner. Will finish cleaning it today then attempt to reassemble. The kit came with a good blowup view and I took lots of pictures.
I've never touched a carb before.....let alone a rebuild. Can't believe haw many parts there are.
- rtreads
...next the C4!
JGZ
To do it right you need a can of vacume!
- hockeydad4-22
You can do it. My first rebuild was a rochester quadrojet way back in highschool. The 3 or 4 extra parts leftover really bothered me at the time.
Have Fun
Have Fun
- airbur
Got it all cleaned and back together. Any pointers on adjusting this thing? It came with decent instructions but I've never done it before. Thanks
- ZOSO
- Moderator
Screw the idle mixture screws in all the way. Softly seat them. back them out 2 full turns as a starting point. Then start from there and do small adjustments from there. This is just the idle mixture.
- airbur
Well, it's back installed in the Bronco. It fired right up but then died and I couldn't get it restarted. Thanks to 2 of the 25+ pictures I took previously, I figured out that the auto-choke was cutting off all air so a few adjustments there and it started right up. I'm sure I need a few more adjustments but for now I'm happy it's running. Also, no more fuel smell, no more backfiring, and now that I adjusted the auto choke, it idles even when cold!:) I'm very happy so far.
I'm still working on where to re-install the fusion transfunctioner, flux capacitor, rotary lubricator, and can of vacuum.
Can anyone figure out what's wrong with the below pic? I didn't notice until I had it installed and had to do some slight re-assembly.....
- BFD305
Diaphram lever/housing is installed backwards.
- airbur
BFD305 wrote:Diaphram lever/housing is installed backwards.
Winner!:) Ford calls it the Accelerator Pump Cover.
- airbur
zillacon wrote:Now you'll be ready to do a 4BBl since you were able to do the Lil guy. You'll have a nice pile of parts when you do one of them.
Haha...yea, I was surprised I didn't have any of the original parts left over when I was done!:) It's running good, but it's a bit rough on cold starts. I'm sure I need to fine-tune a bit.
Shawns Fords
I have one of them on my 78, that damn accelerator pump likes to wear out a lot. but it never fails an E test.
Good job rebuilding it. I enjoy working on carbs for some strange reason.
- airbur
So after a day or so, it seems to be running fine when warm. But when cold, it starts right up, then runs rough and ends up dying. I'm sure it's the choke, but am at the end of my rope as far as trying to adjust it correctly. Any ideas?
The choke has the air opening adjustment and the high idle speed adjustment. Might have to step up the high idle a little to keep it from dying. Rough running is choke opening adjustment.
