exhaust ?
- Justin
Re: exhaust ?
While we're on the topic I wouldn't mind a referral to someplace Denver or north.
- Justin
Re: exhaust ?
I'll check out Exhaust Pros. My rig isn't nearly pretty enough for a high dollar job, however attractive its ass may be. Thanks!
- goldenboy_cp
Re: exhaust ?
the muffler guy i had put a one off middle mufflerin my integra and did great job on my friends diesel and with stacks is downtown colorado springs on platte
TRAVIS HOYLE
- sbolt19
Re: exhaust ?
goldenboy_cp wrote:the muffler guy i had put a one off middle mufflerin my integra and did great job on my friends diesel and with stacks is downtown colorado springs on platte
That guy is REAAAAALY expensive for an EB. I stopped in one day and he quoted me over $600 to replace dual with a set of 12" Thrush turbo mufflers & bung holes for my O2 sensors. Hell, that is as much as my dad paid for his F-250 with a 460 that needed a cat, muffler & tail pipe. BC sells their 2 into 1 setup for $200+ s/h.
- Justin
Re: exhaust ?
What would a reasonable price be for a 2 1/2 into 3" off my long tube headers out through the body on the passenger's side. I'll need a muffler and will be having them weld in a high flow cat I already have.
- airbur
Re: exhaust ?
AAA Performance Muffler, 303-806-8634. Just south of Hamden on Broadway....great little shop. Did my duals (I provided the mufflers)...would highly recommend.
http://www.aaperformancemuffler.com
They had mine completed in about 6 hours.
- sbolt19
Re: exhaust ?
Justin wrote:What would a reasonable price be for a 2 1/2 into 3" off my long tube headers out through the body on the passenger's side. I'll need a muffler and will be having them weld in a high flow cat I already have.
Justin, that BC kit that I mentioned is a 2.5" in, 3" exit. Doesn't include the cat, but if you can weld, I would do their kit. From the talk on CB.com, it sounds really good and has good performance. I have been kicking that idea around for a while myself. I have a dime size hole in my pass side tail pipe, behind the muffler that I can hear that just bugs the sh*t outta me. Everywhere I have shopped pricing, it all is above $400 for header back.
- airbur
Re: exhaust ?
sbolt19 wrote:Justin wrote:What would a reasonable price be for a 2 1/2 into 3" off my long tube headers out through the body on the passenger's side. I'll need a muffler and will be having them weld in a high flow cat I already have.
Fyi....."Complete system bolts up to our headers only."
- sbolt19
Re: exhaust ?
airbur wrote:Fyi....."Complete system bolts up to our headers only."
Damn....didn't read that complete description
- Justin
Re: exhaust ?
I've thought about doing that BC kit eve though I don't have their headers. I figure my headers are longer, so I may be able to modify it. The only down side is that it has 2 entries on the muffler which means I won't be able to use the cat I have.
- airbur
Re: exhaust ?
For the price of the BC kit plus shipping, I would go to a local shop and get a fully custom version for your truck for just a bit more. Save yourself the cutting and welding that may be necessary. But that's just me.
- GMAN
Re: exhaust ?
Have a BC's 2 1/2 into 3" with a magnaflo on my roadster, really like the fit
Made my own tail pipe ..be careful when the soft top is rolled up like a safari.....the exhaust can roll back in and make back seat riders sick if the exhaust does not draft correctly.. I did a lot of trial and error with the exit to keep the fumes from swamping the kids in the back seat.
GMAN
70 Roadster 347 burnt orange
Shawns Fords
Re: exhaust ?
I would send you to Hanksville hot rods on south Santa fe, not only is he a friend of mine but does all TRUE Mandrel Bends and can do your roll bars as well as mounts to convert to modern Ford engines. Stop in or call him and tell him Shawn referred you. No I dont get brownie points for that. If anything stop in to see some of his other projects.
http://www.hanksvillehotrods.com/
- ZOSO
- Moderator
Re: exhaust ?
Hank does do killer work. He's done some exhaust for a buddy and a few cages for a few friends cars but its $$$$$$
- Rox Crusher
Re: exhaust ?
zillacon wrote:If you want a high dollar sweet ass job go to Hanksville Hotrods on the south end of town.
wholly mackerel, I talked to these guys as they are close to my place.......
ballpark price for dual stainless exhaust with new mufflers and cats (they won't install used cats) was 1,600 +/-.
I was thinking maybe 1 - 1,200 but not anything close to 1,600
I guess I will check with exhuast pros as it will be worth the trip
- landshark
Re: exhaust ?
try chucks exhaust on sante fe... hes pretty good and he will work with you.. really nice guy. As you can imagine his name is chuck ;)
he did my fullsize and I will be taking it to him to do the 76 when its ready.
1600 South Santa Fe Denver, CO 80223
303-777-7646
http://chucksdiscountmufflerandbrake.com/
303-777-7646
dsmith01
Re: exhaust ?
I will second Chucks work. He did my Heep exhaust before I sold it. It was somewhat of a custom setup -4.5" lift with TNT long arms and dual triangulated rear links. He was able to use a compact muffler and jam everything up really close to the floor for maximum clearance against the rear links.
I will probably take my Bronco to him if I can ever get the engine running right.
