Front disk brakes, brake booster,rear seat?
totalchaos
Post by totalchaos »
Also looking for front or rear disk brakes, brake booster, and a rear seat..for a 66 bronco with a dana 44 front, 9 inch rear
Im your huckleberry
Re: Front disk brakes, brake booster,rear seat?
Post by akaFrankCastle »
I'm in the middle of a disc install on my 44. If ya want, I'll shoot you all the part numbers and what not when I'm done so you can do it too. Planning a write up as well.
totalchaos
Yes please do that would be very helpful thanks
Im your huckleberry
Will do. You guys have any good salvage yards down there in La Junta? If not, I'll keep my eyes open for another set of spindles and backing plates.
totalchaos
akaFrankCastle wrote:Will do. You guys have any good salvage yards down there in La Junta? If not, I'll keep my eyes open for another set of spindles and backing plates.
Just one so its hard to say if they will have the parts I need but u never know just have to call in and check it out..
Im your huckleberry
UPullandPay here in the Springs has been having a rough time with Chevy spindle selection. Found an oddball today while I was REpicking spindles. A 77 C10 4x4 with one 1/2 ton spindle and one 3/4 spindle. Had to go knock the covers off an auto-locking hub to get my second spindle. Anyhow, there is only one 1/2 spindle you could use left there. I do have two extra backing plates now though.
totalchaos
Ok cool ill have to get with u on those..what rotors and calipers would I be looking at or what kind of vehicle would I pull it from?
Im your huckleberry
From everything I read:
Spindles can come from 72-76 K5 Blazers and Jimmys and 72-77 10 and 15 Series GM trucks
Here's where I got all my info:
http://classicbroncos.com/tech/chevy-disc-brake-conversion
Post by Viperwolf1 »
akaFrankCastle wrote:From everything I read:
Man, that tech article has to be over 10 years old.
They just don't write them like they used to.
cobshane
Post by cobshane »
and still well used i used the same article to do mine. i did have the same spindle problem as well on my salvage seach untill i ran in to a big old cherokee i think a 79 with a dana 44 with the exact brake setup as gm. 76-79 is the years that use the setup i think with dana 44s.
totalchaos
akaFrankCastle wrote:They just don't write them like they used to.
Thanks Guys now I have an idea on what Im looking for time to start searching
Im your huckleberry
