Power Steering steering shaft?
totalchaos
Post by totalchaos »
Looking for a steering shaft out of a bronco that had power steering Im converting my 66 bronco from manual to a stock power steering set up and my steering shaft is totally different
Im your huckleberry
cobshane
Re: Power Steering steering shaft?
Post by cobshane »
You can use a 3/4 round to a 36 spline ujoint just cut the shaft and weld the smooth part in. I got one at ontrack off santefe road.
cobshane
Post by cobshane »
coberlyshane wrote:You can use a 3/4 round to a 36 spline ujoint just cut the shaft and weld the smooth part in. I got one at ontrack off santefe road.
Can't remember for if it was 36 spline. You might want to count.
totalchaos
Ok Ill check it out and get back with you thanks
Im your huckleberry
Woodscaper
Post by Woodscaper »
I think it is 13/16" x 36 spline on that box.
cobshane
Post by cobshane »
jtsbronc wrote:I think it is 13/16" x 36 spline on that box.
Ya your right it is 13/16. That's what you need. Alot easier than swapping out a column.
totalchaos
You know where I might find one?
Im your huckleberry
cobshane
Post by cobshane »
Ontrack performance off santefe road. Or summit racing. West coast broncos. To name a few.
totalchaos
I about have all my steering parts and i think i found that knuckle on ebay but it say 13/16 3/4 by 36 tooth would that be the right one??
Im your huckleberry
cobshane
Post by cobshane »
totalchaos wrote:I about have all my steering parts and i think i found that knuckle on ebay but it say 13/16 3/4 by 36 tooth would that be the right one??
That's the one! The 13/16 is the box side with splines, and the 3/4 is the smooth side for were you cut the steering shaft.
totalchaos
Awesome I just wanted to make sure before I ordered thanks for the help!
Im your huckleberry
