oem D44 hub and outer axle
Brianut
Post by Brianut »
looking for a cheap stock ford hub(could be aftermarket I suppose), good usable condition, as well as an outer axle shaft for d44, either side
I am working on an idea for a little project Welding , the u joint doesnt have to be good as I plan to cut that off anyhow.
cheap is key, just in case it doesnt work out
Re: oem D44 hub and outer axle
Post by Rox Crusher »
I think I have a usable set of hubs / rotors off my D44
Let me look and get back to you
Brianut
Post by Brianut »
Thanks for the hubs Rox, now I just need an axle.
Anyone??
Post by Kinder »
Brian, I've got the hubs to give you from Rox. I'll swing by sometime later this week and drop them to you.
Brianut
Post by Brianut »
That would be cool but maybe hold off for a little.
I have told myself I don't get them unless I drive the Bronco to your house to pick them up.
An incentive to get these brakes done, sooner than later.
been kinda drool lately.
Post by Kinder »
Gotcha, let me know if you need help wrenching, I promise to leave the hubs at my place.
Brianut
Post by Brianut »
I should be good, only have to bleed brakes and PWR steering sytem to be driveable, aiming for tonight.
recruiting a frind for pedal pressure.
Just might drive it to work on friday as it is supposed to be 46 and sunny. migth be a little chilly with the bikini top.....
