may need a stock pitman arm..... You tell me
- trei75bronco
I have a 3" drop pitman arm and Im putting in a steering kit tomorrow do you think I will need a sock one??? If so who has one???
- airbur
Re: may need a stock pitman arm..... You tell me
How much lift do you have? If it's 2.5" sus or less you prob don't need the drop pitman. Hut carries them for $60 I think.
- Justin
A little more info on the steering kit would be useful. If you're going tie rod over then no, you shouldn't need a drop pitman arm unless you're lifted a bunch (5+ inches).
- Jesus_man
It really comes down the geometry of your steering. You want your track bar to be as flat as possible and you want your drag link to match that angle. I wouldn't try getting additional parts until you put your steering on.
