#1: Not if you have an electronic choke. For a manual choke, yes, you do need it. #2: No idea. #3: The brake warning light would indicate a problem with the braking system when starting the truck. I don't really see it as needed if your braking system is in good condition (many, including mine, don't work). I have always figured it was probably something that was installed by a special team of Ford lawyers on the factory floor.
Throttle and Choke are not the same thing for Bronco dash layouts. The throttle cable actually attaches to the gas pedal linkage, inside the cab, and just about the pedal. Purpose is to set a higher than idle RPM setting, for whatever reason. I find the throttle works great in the cold mornings for me, seeing as my manual choke on the ol' Holley was not working well.
I also cannot find any dash label light bars through any of the parts houses. Sounds like its time to make a new product for the market!
Stroppe'd 1972 Sport, 302, 3 speed with old school Duff floor shifter, T shift Dana 20 with JB Fab twin stick, 4.11 gears with Trac-loc, Lincoln hydroboost, Chevy disc conversion, WH gas lift gate shock kit, 33" Duratrac tires on slots and about 2.5" of lift, Stroppe installed: bumper braces, dual shocks on all four corners, GM power steering, trans cooler mount, auto shift column, rollbar.
Thanks a ton for the help. Glad I am not the only one who can't find them from the supply houses. Looks like I need to call Don and see what he has in stock. Been wanting to head down there for a while, now I have an excuse.
Punisher - if you want to produce them, I will be your first customer. I'm sure I am not the only one who needs them.
The throttle cable is to run higher RPM's when you want to run something like a PTO winch.
The light bars I have seen on ebay selling for as much as $100.00 + a set. I have at least the heater side (I think it's the heater side) you can have at N/C. I may have both sides but I'll have to look when I get home.
If the light bars are going for $100.00, it is very unlikely that Don is going to have them laying around. There has got to be a market for them. I have never seen them for sale on eBay and I have been regularly searching for dash parts for months.
76 - There is no way I will take your light bars. I will wait for Punisher's reproductions. Besides, may be asking for someone to break into my truck
69 - Here is the pic with all 3 diffferent Dash Layouts:
Punisher - I ordered those last week and should be here Tuesday. First order from BC. I think that is just the strip that go inside the bezel that I don't have. Isnt there a chrome bezel around that strip that holds it in place?
Yup, sure it. I suppose that is the one piece that is not reproduced. Shouldn't be too hard to fab something out of sheetmetal. Maybe a nice stainless steel or aluminum. Chrome would work too for the stock look. Hard part is finding the template to work off of.
I wonder why mine doesn't have the controls on the outside of the column? This is probably the messiest part of the vehicle, Everything from the Dash down is a mess, you can see the rust holes along the door jambs also. Maybe someone changed the dash out. I know it has been out as the corners are filled in with caulking which is going to be a fun time cleaning that out.
i've got the stock bezel/labels for the heater controls you can have for free, its not perfect but since you're getting the strips it'll help, i converted mine to vintage air, so i don't need the heater bezel/labels anymore, lemme know if ya want it
Entourage wrote:Punisher - I ordered those last week and should be here Tuesday. First order from BC. I think that is just the strip that go inside the bezel that I don't have. Isnt there a chrome bezel around that strip that holds it in place?
You can have these if you want them!
I might be interested in one of these, if you are offering. We're thinking about getting a plastic injection prototyper at work. Might be a good project to try out.
I know someone that works for a plastic injection company. He lives just north of Co Springs. I wonder how many plastic injection companies are down there.
I don't think Entourage needs all three. Your more than welcome to one or all of them depending on his response.
76 - if you are really offering the two light bars for my dash, I will accept your very generous offer. I owe ya lunch in the cafeteria or something ;). Thanks again!
Entourage wrote:76 - if you are really offering the two light bars for my dash, I will accept your very generous offer. I owe ya lunch in the cafeteria or something ;). Thanks again!
Two are yours as stated (it's part of my Bronco karma and you can thank akaFrankCastle for that) , the other I'll give to akaFrankcastle. FYI, I started to take them apart and clean them up. They're lookin' pretty sharp and will go great with your purchase from BC Broncos.
I'm working Thursday and Friday, do you want to pick them up at CaridianBCT?
