Trying to start
B.O.B.
Trying to start
Post by B.O.B. »
I just finished my efi swap/ upper moter rebuild and trying to start it up. It seems that only a few cylinders are firing (check with a temp gauge on headers). Any ideas what could cause this? Anybody want to come over and help?
B.O.B.
Re: Trying to start
Post by B.O.B. »
I did have it tdc when I installed the diz, and then went around the diz for the firing order on the plugs. Should be right, right?
Re: Trying to start
Post by Viperwolf1 »
TDC after the compression stroke or TDC after the exhaust stroke? There are 2 possible firing orders, 15326378 or 13726548. Ignition firing order needs to match the firing order of the cam. Ignore injector firing order. Rotor turns counter-clockwise.
