O2 Bungs or Tap
- ZOSO
- Moderator
Re: O2 Bungs or Tap
Aaa metric. I think they are 18x2.5mm or something like that. Or exhaust pros. I've got some there too.
- RJLougee
Re: O2 Bungs or Tap
You can also cut down a set of 18mm spark plug extenders. You can usually find them in the HELP! section of the local auto parts store. Works like a charm and usually less $$. If you have the time to wait, Summit sells them for $5 or so and I usually have some on the shelf.
Joe
Joe
Re: O2 Bungs or Tap
Yep. Same thread as the big spark plugs. I think I have some spark plug taps.
robs68
Re: O2 Bungs or Tap
I was able to find the bungs at NAPA for about three dollars
