Exploder parts
Re: Exploder parts
Post by Entourage »
Good to know. Sorry in advance if this is a newby question. I have read threads on CB.com about the serp set-up as a great add to their Broncos, but have never heard how it helps. Is it to add to any motor (302/351/5.0)? Is it so you can add on board air or air conditioning?
Re: Exploder parts
Post by Viperwolf1 »
Entourage wrote:Good to know. Sorry in advance if this is a newby question. I have read threads on CB.com about the serp set-up as a great add to their Broncos, but have never heard how it helps. Is it to add to any motor (302/351/5.0)? Is it so you can add on board air or air conditioning?
The big benefit is the short length. It easily clears the radiator with the big clutch fan. The PS pump is better than the stock Bronco pump. The alternator puts out 130 amps. AC can be used on a 302. For a 351 you might have to clearance the inner fender.
Re: Exploder parts
Post by Entourage »
Thanks Vipor for the info. Sounds like a great add sometime.
cobshane
Re: Exploder parts
Post by cobshane »
plus one belt to three to change out! oh yes life is simply easier. auto tensioner makes it that much easier as well.
Re: Exploder parts
Post by Rox Crusher »
zillacon wrote:Ill be headed back on Sunday if anyone wants to tag along.
If I can get a hall pass I will join you
75dlydrvr
Re: Exploder parts
Post by 75dlydrvr »
Man, I wish I could go...
