How to keep a Bronco from rusting
Figured out how to prevent a Bronco from rusting:
1. Assemble your own power steering hose, having never done it before.
2. Fill your power steering reservoir really, really full.
3. Have said hose slip out of the fitting, blowing at least 1/2 a quart of PS fluid.
I've got PS fluid all over the inside of the engine bay, all 3 bays of my garage (with my Mazda parked in one of them) and all over my workshop. I think the highest dot of fluid I saw was at least 10' up the wall. Turn out 1500 psi can make a mess. At least I've rustproofed the truck for the next couple years.
The good news? I now have power steering. Thanks again to everyone at the shop day for helping make it happen. I think my Bronco wants to be a sports car now.
Re: How to keep a Bronco from rusting
Post by Gunnibronco »
I wish brake fluid had the same anti-corrosion properties. I used a pressure bleeder to bleed my brakes, only to have the make-shift lid cut loose & soak my engine compartment with brake fluid. The only thing it did was make my new Bloody Knuckle arms & freshly painted axles & steering look as bad as the rest of my truck. I really thought I had it all cleaned up, until the next morning when I noticed lots of wrinkling going on.
Power steering is in my list of top upgrades done to my truck. What a dream!
Chad
It's amazing. I almost drove my truck into a tree the first time I turned it while moving. The 4x4x2 box is powerful and I can now 1 finger turn my 35x13.5 mudders on dry pavement. It's like magic.
I ran for a couple years with no PS & 33's. I can't imagine getting into a parking place with 35's and no PS. Your arms must look like Arnold's did in Conan the Barbarian.
Its kind of like having to pull a tooth out of my steering wheel after adding power brakes. Then having to pull another tooth out of my steering wheel 10 years later when I upgraded to hydroboost. I'm not a fast learner. Good thing my family is full of dentists, LOL.
Chad
Nice. Hydroboost is next on the list once I figure out what is going on with my fuel pump. Looking forward to some more stopping power.
Shawns Fords
Post by Shawns Fords »
LOL atleast it is sealed for a few years.
Post by akaFrankCastle »
Gunnibronco wrote:I wish brake fluid had the same anti-corrosion properties. I used a pressure bleeder to bleed my brakes, only to have the make-shift lid cut loose & soak my engine compartment with brake fluid. The only thing it did was make my new Bloody Knuckle arms & freshly painted axles & steering look as bad as the rest of my truck. I really thought I had it all cleaned up, until the next morning when I noticed lots of wrinkling going on.
Chad
I made a huge brake fluid mess when I was putting in my hydroboost. On a positive note, the crappy flat black paint that was once in my engine bay has given way to the original mallard green in spots now.
cobshane
Post by cobshane »
The best brake fluid cleanup is water and soap. Brake cleaner just does not do it. Brake fluid is some nasty stuff when it sits on paint.
akaFrankCastle wrote: I made a huge brake fluid mess when I was putting in my hydroboost. On a positive note, the crappy flat black paint that was once in my engine bay has given way to the original mallard green in spots now.
My new old color is pale yellow.
coberlyshane wrote:The best brake fluid cleanup is water and soap. Brake cleaner just does not do it. Brake fluid is some nasty stuff when it sits on paint.
Never had to clean up that much before. Brake fluid is my arch nemesis, I hate that stuff. It even "feels" weird.
Chad
