saggy rear end ha!
cobshane
saggy rear end ha!
Post by cobshane »
Make all the jokes you need, i can handle it.After installing the tire carrier assembly, im saggin. Anyone have a add a leaf or you think i can use the spare leaf setup i have and add on to the existing ones. I may have make a run to the bronco hut to get a leaf spring setup. I do want it to be right, but i am trying to save some kizash as well. I need maybe a extra inch or two.. this needs to happen before Ouray.
cobshane
Re: saggy rear end ha!
Post by cobshane »
zillacon wrote:Don't sweat hauling extra stuff down to Ouray. You are more than welcome to put stuff on my trailer or inside the bronco when its getting hauled if you need room or need to shed some weight.
Thanks dude but just need it sitting right. Im going to bite the bullet and get some springs. I dont know if you have enough room for the Bakaugans.
What do you have for lift springs now? Mine did the same. Just replaced with new ones and it's sitting right now. However, I have some leafs that you could swap into your existing pack and maybe level it out. Trouble is it'd be trial and error and getting them to ya could be tough.
I have two longer leafs from a 5.5" pack, one 3.5" pack in tact and one 3.5" pack with two of the longer leaves bent.
cobshane
Post by cobshane »
It has no lift in the rear. Dana 70 with higher spring perches made that possible. I already bought and paid for a set.
Thanks for your offer though. Going with 2.5 wh leafs from the Hut. Just need to get down there sometime before the trip.
airbur
Post by airbur »
Dana and Melissa happily meet up with me when I need stuff. Ask her if she'll meet you 1/2 way. Many times I25 and Lincoln is convenient for Dana.
cobshane
Post by cobshane »
airbur wrote:Dana and Melissa happily meet up with me when I need stuff. Ask her if she'll meet you 1/2 way. Many times I25 and Lincoln is convenient for Dana.
I'm already setup. installing springs tonight. that's exactly what I did though. Thanks
