Jonah had his front ujoint go bad on his rear driveshaft. It also damaged both pieces that hold the U-joint (part on the rear ouput from the t-case and front part on the CV) If anyone has anything let us know. Would like to pick up ASAP.
Thanks
Scott
303-489-1209
Need rear drive shaft or CV-Joint parts ASAP
- BFD305
- Justin
Re: Need rear drive shaft or CV-Joint parts ASAP
Can't help with parts, but if you wind up buying new, check with a local driveline shop. Having mine done cost about $10 with better parts than it would have cost me to get the parts and do it myself.
