Have a few odds and ends I'd like to pick up for the '69 prior to my putting it on the market.
Defrost duct hose, the one that runs from the heater box to the actual duct under the driver's side
Temperature control valve, in the coolant line that allow you to change the temperature
Temperature control cable. I've got the knob. No cable to run to the valve.
Rear seat belts. Stock is fine. I just need something I can either bolt in or hand off to the new owner that will compliment the flip and fold rear seat I will be picking up from Entourage, hopefully this weekend.
Rear shocks for a 2.5"-3.5" lift. Used are fine. I'm planning to swap over the rebuilt leafs I have and want to make sure I have the correct length shock when I do.
Cheap is good, but I'm flexible. I'd go yank most of this stuff from the salvage yard, but I'm heading out of town on Sunday so won't have much time over the next week.
Anyone know a good place to get front Dana 30 brake drums? Advance can't order them. No longer in the system.
Stuff Wanted
- akaFrankCastle
Stuff Wanted
JGZ
Re: Stuff wanted
I think I have every thing on your list except the shocks.Gimmie a PM and we can set something up
- akaFrankCastle
Re: Stuff wanted
WIll do. And I just realized I posted in the wrong section. Damn.
- ClayJ
Re: Stuff wanted
I have a set of lap belts that used to be on the front seats. If they'll work on the rear seats you're welcome to them.
- akaFrankCastle
Re: Stuff wanted
Thank ya Clay. I think Jay has me set with everything minus the shocks. If not, I'll give you a shout.
