460 engine swap
bigbronco
460 engine swap
My brother has a newly rebuilt 460 engine, my 302 is done, but I dont know if the 460 will bolt to a C-3 trany "which I just had rebuilt". Can anyone help me with this?
- ZOSO
- Moderator
Re: 460 engine swap
if this is going into a 66-77 you will need to find a bigblock c6. You also need to cut out the inner fenders. cut off the motor mount towers. possibly cut out the firewall to move the engine back. The 460 isnt small. a 351w is a tight fit in the eb let alone something that is inches wider, taller, longer, heavier. then you have to find a way to keep it cool. the EB radiator is really small. Trying to keep a bigblock cool with one would be hard to do. In the end it would be cheaper to rebuild the old 302.
- akaFrankCastle
Re: 460 engine swap
zillacon wrote:Check with dahli, Don Allison. I think he has a 460 in his.
An EFI 460 at that. And that thing is jammed in there. The fab work alone to jam a 460 into an EB would be enough to frighten me away.
- sbolt19
Re: 460 engine swap
The other thing you have to think about is the frame strength. EBs have good frames for their size, but you might need to beef the frame up so you don't twist it in two. Definitely get ahold of Don to check the ins and outs, and if you are in Colo. Springs, go by his yard and look at it, that beast is sitting in the garage down there.
Shawns Fords
Re: 460 engine swap
wish I had a SBF to trade you. I could use a 460 for my F250. then I wont have to yank the one out of my F100. I honestly wouldnt mind a Modified built up for my 69 Bronco to accommodate for the bigger axles and tires.
The benefit I see with the BBF is that it is a torque monster and if you have a lifted EB and want to develop some serious low end power a BBF has it. I would worry about the torsional stress it puts on the chassis as well, but need to box that frame in if your going to do something like this.
- ZOSO
- Moderator
Re: 460 engine swap
Shawns Fords wrote:wish I had a SBF to trade you. I could use a 460 for my F250. then I wont have to yank the one out of my F100. I honestly wouldnt mind a Modified built up for my 69 Bronco to accommodate for the bigger axles and tires.
EB's have a fully boxed frame already. You'd need to add crossmembers. Maybe more plates on the frame.
I do have to say that the BBF is a great motor. Just a little expensive to build if you dont keep it stock. I put a lot of money into mine and didnt even go with a stroker kit. I'd love to
a set of nice heads on it and let it breathe a little better too.Rob
Shawns Fords
Re: 460 engine swap
ZOSO wrote:Shawns Fords wrote:wish I had a SBF to trade you. I could use a 460 for my F250. then I wont have to yank the one out of my F100. I honestly wouldnt mind a Modified built up for my 69 Bronco to accommodate for the bigger axles and tires.
I do have to say that the BBF is a great motor. Just a little expensive to build if you dont keep it stock. I put a lot of money into mine and didnt even go with a stroker kit. I'd love toa set of nice heads on it and let it breathe a little better too.
Thats right, I forgot it is a boxed frame. I havent had a lot of wrenchin time on it lately and tend to forget things. I dont think I put a ton of cash into my 460 but it is a good sized amount of money. I think when I swap it into my F250 I am going to use all of my new goodies I had for my 429 in it also. Except for the camshaft. Its too radical.
