'73 - '75 Upper Power Steering Shaft
cplynn
Post by cplynn »
I accidentally boogered the splined end of my upper steering shaft while using a steering wheel puller to pull off the steel flange that bolts to the rag joint. Now my new WH lower steering shaft won't fit the upper. If anyone has an upper '73 - '75 power steering shaft (minus the steel flange that bolts to the rag joint if possible) please let me know.
I would opt for a new tilt column, but I can't justify dropping the $$$ for one right now.
Thanks.
