EFI questions-Fuel pressure guage and regulator
tod
Post by tod »
Does anyone have a recommendation for a fuel pressure guage and regulator?
Pictures would be helpful too.
I am using 1991 Mustang fuel rails.
Thank you,
Tod
1966 Bronco - 408 roller cam, Explorer serpentine, NV3550 5spd, hydroboost, 35s, 4.56 gears
Re: EFI questions-Fuel pressure guage and regulator
Post by Viperwolf1 »
The stock regulator is fine unless you have a unique combination of parts that makes an adjustable one necessary.
I used AN-6 hose so adding a gauge was easy.
tod
Post by tod »
I would like the ability to monitor and play with the pressure.
What brand are you using?
Can I adapt it to fit on the shraeder valve? I am using the stock rails and fittings.
Thank you, Tod
Monitoring pressure with a gauge is good. Playing with the pressure may not be so good. Really if the EFI system is working as it should there is no reason to change the pressure.
I have seen gauges that screw to the schrader port. I picked mine up at On-Track. http://www.ontrackperformanceparts.com/
tod
Post by tod »
I like the idea of keeping it simple too. I will just get the guage for now.
I love the look of your hoses with AN fittings. I like the idea of a more secure connection too.
I will have to learn how to build the hoses, hopefully the tools are not cost prohibitive.
I used a vice, a couple wrenches, and a sharp chisel to cut the hose.
tod
Post by tod »
Viperwolf1 wrote:I used a vice, a couple wrenches, and a sharp chisel to cut the hose.
That sounds like how my dentist might describe how he extracted my wisdom teeth.
You make everything sound so simple.
Thanks again,
Tod
Kermit484
Post by Kermit484 »
I also used the stock regulator and picked my pressure gauge up at On-Track.
'77 - efi, 302, detroit 9"rear w/4.56, D44 (locked), 35" M/TR's, Roll Cage
