When I added a lunchbox locker to my D44 a few months ago, I noticed that I had mismatched spindles.
One had a deeper ring than the other, and the axles each had shoulders that fit into the ring, but one was longer to fit the deeper ring. There was also something like a large dust plate that sort of sealed the whole spindle off. When I put the whole thing back together I tried to put the long axle with the short spindle and it wouldn't work. I had to match the spindle to the axle.
Most of the axles I see in the junk yard have neither shoulder nor dust plate on them.
Many of the axles that Chaser has for sale don't have them, and neither to the photos of the axles for sale on most Bronco parts houses.
What's the story with the shoulder and plate and should I care?
And the biggest question, If I do the chevy or ford disc conversion, will my mismatched axles cause me any problems?
Should I buy a different axle?
viewtopic.php?f=8&t=3271
Dumb question time - Axles and splindles
- ClayJ
- wildhorses
- VENDOR
Re: Dumb question time - Axles and splindles
This just has to do with 66-71 1/2 spindle/axle vs 71-75 spindle axle. As you have noticed they are different. Basically just keep the early with the early and the late with the late and you won't have a problem. Keep in mind the GM style front disc will be the "late" style. Look at our instructions for solution.
http://cdn.wildhorses4x4.com/downloads/ ... 2-1-11.pdf
http://www.wildhorses4x4.com
Like us on Facebook for special deals and promotions.
http://www.facebook.com/WildHorses4x4
- Booger
wildhorses wrote:This just has to do with 66-71 1/2 spindle/axle vs 71-75 spindle axle. As you have noticed they are different. Basically just keep the early with the early and the late with the late and you won't have a problem. Keep in mind the GM style front disc will be the "late" style. Look at our instructions for solution.
Good to see wildhorses on here. We really appreciate it when you post up especially to answer tech questions. Thanks.
Now if you would market the rock sliders like the ones on NightMare I'd be on them in a heartbeat.
