In-tank pump
rdanford
In-tank pump
Post by rdanford »
Well, more problems with the EFI swap...the 2nd (replaced after 1500 miles) pump is only building 15-20 psi so I'm dropping the tank again and probably going to have to replace. Has anybody had these types of problems? What could be the cause?
Royce
2006 4Runner V8 Sport Edition
rtreads
Re: In-tank pump
Post by rtreads »
I have not had any problems with my Walbro 255 pump.... except its LOUD. Even in the tank.
rdanford
Re: In-tank pump
Post by rdanford »
Yeah, both have been loud but now both have died within months of being installed.....changed the filter and pickup screen last time....such a pain to drop the tank.
Royce
Re: In-tank pump
Post by Viperwolf1 »
Is it an old tank? Maybe it has some junk in it.
rdanford
Re: In-tank pump
Post by rdanford »
In, it the Sherman that I bought this last July for the EFI swap. Going to pull it, clean it and hope for the best.
Royce
rdanford
Re: In-tank pump
Post by rdanford »
Got the tank dropped this evening...everything looks ok, just a bit of dirt in there (BMF could have cleaned some out but it doesn't surprise me anymore).
One thing that looks a like strange is the hard line from the pump looks to be kinked were it bends...anyone have an uninstalled Sherman/BC Tank to look at the in-tank hard line?
Royce
rdanford
Re: In-tank pump
Post by rdanford »
Bump...What about a FPR because I'm having the same issues again. Is there a way to test the FPR or is it best to just replace it? Fuel pressure has dropped to 25-30psi even with a new fuel filter. I don't want to drop this thing again! Any help would be great. I have a hard time thinking a very small amount of dirt could kill a fuel pump.
Royce
Re: In-tank pump
rdanford wrote:Bump...What about a FPR because I'm having the same issues again. Is there a way to test the FPR or is it best to just replace it? Fuel pressure has dropped to 25-30psi even with a new fuel filter. I don't want to drop this thing again! Any help would be great. I have a hard time thinking a very small amount of dirt could kill a fuel pump.
Remove the fuel return line and allow it to flow into a container. You want to see if there is any fuel coming out when the pump is on and the pressure is low. If there is fuel coming out the regulator is allowing it and is bad. If no fuel comes out the supply side has a problem.
RJLougee
Re: In-tank pump
Post by RJLougee »
I just installed the same tank in my Sons EB and there was a slight bend in the hard line in the tank, but certainly not a "kink". Yours may have gotten extra bent when the rubber line from the pump was pushed onto it???
If you are driving the EB any distance in the heat you should be getting vapor lock issues if the FPR is bad. It's not an absolute; however, in the heat we've had lately I would expect it.
There are a number of good write-ups out there on the Mustang sites about testing the fuel pump, etc... Just make sure you're reading the '87-95ish versions and not the later returnless system advice.
HTH, Joe
rdanford
Re: In-tank pump
Post by rdanford »
Just got the tank dropped again this afternoon and will be tearing into it tomorrow...FPR seems to be good so looking into the pump as of right now.
This EFI swap has been nothing but issues, about ready to just give up on it
Royce
