The only part number I can find is on a retaining ring for the bearing. It's PMR88128A. Based on some internet searches, it look like like that's timken number R88128.
Based on a thread on Pirate, it is interchangeable with:
Timken bearing 514003P came as a sealed bearing and included the pressed on ring that I needed. $18.99 from Autozone (special order)
I can't find any specs on this bearing and I don't want to press it off until I know I have the right part number. Can anyone verify that either of these part numbers will work?
And my caliper bracket is between this bearing and the axle flange. How the heck do I press that bearing off?
I am not at all opposed to going with a set of tapered bearings if it's easier and cost effective, but I have not idea where to start with that.
