Rocker trim
- Badlands
Rocker trim
Looking for original rocker trim and clips. Doesn't appear to be reproduced or sold elsewhere.
- akaFrankCastle
Re: Rocker trim
Ah, dammit. There was a set just up on Craigslist maybe a week ago in the Denver area for 20 bucks or so. I was gonna pick them up just because. They're gone now. I'll keep an eye out though.
Might PM Dalli and see if he has any at his COS yard.
- Badlands
Re: Rocker trim
Thanks Frank. That sounds like an incredible deal and much less than what I anticipated. Just to clarify, this set was for the outside of the rocker under the door with the clips? Like on this Bronco I have seen around.
Funny there no reproductions out there.
- hockeydad4-22
Re: Rocker trim
That trim looks a lot like the early mustang rocker trim. I may have some of it laying around if it will work. I am sure you will have to cut it to fit. I will look when I get home. It would be from a 66 stang.
- akaFrankCastle
Re: Rocker trim
Badlands wrote:Just to clarify, this set was for the outside of the rocker under the door with the clips? Like on this Bronco I have seen around.
That would be correct.
- Badlands
Re: Rocker trim
hockeydad4-22 wrote:That trim looks a lot like the early mustang rocker trim. I may have some of it laying around if it will work. I am sure you will have to cut it to fit. I will look when I get home. It would be from a 66 stang.
Let's take alook at the breakfast if you have time. That would be great. Thanks.
Frank, that was a
g deal. If something like that pops up again, snag it!- hockeydad4-22
Re: Rocker trim
I found one side - might be long enough for both, I dont know. I will bring it to the breakfast.
just in case, here is a link for one of the mustang vendors who sells the trim and clips.
http://www.cjponyparts.com/rocker-panel ... 6/p/RPM1L/
