trying to get my efi swap running and running into a different problem. i have a power wire through the dash that is getting red hot. Could this be because I do not have the power wire to the old coil connected? Is it supposed to be connected?
it seems to me that most of the harnesses are plug and play and do not use any of the existing wiring. So i do not see how adding a second harness could cause the old harness to overheat.
Any suggestions?
Bobby
