Offset Front Axle
75DBE
Offset Front Axle
Post by 75DBE »
Well, I'm not looking forward to the answer, but...I noticed after getting the front tires on my bronco that the driver's side tire extends beyond the fender like 2 inches while the passenger side tire sticks out from under the fender very little or not at all. I assume this can't be good. Might some of this be corrected when I replace C-bushings and do an allignment, or am I just grasping at straws? Thoughts?
Colorado75bronc
Re: Offset Front Axle
Post by Colorado75bronc »
You need an adjustable trac bar, and or trac bar drop or riser bracket
Yup. How much lift are you running? Your angles look pretty good, I'd start with an adjustable trac bar.
75DBE
Post by 75DBE »
I have new shocks and new 3.5" WH springs in the front and new shocks, 3" blocks and old leaf springs in the back.
x3 on the adjustable track bar. You length it and it pushes the axle to back under center.
The track bar controls your left to right placement of the axle. It's connected to the drivers side frame and runs down to the passenger side of the axle.
Post by hockeydad4-22 »
Agreed on the track bar - I highly recommend the axle riser bracket instead of the frame attached drop bracket. I could tell you why but they say a picture is worth 1000 words.... (see the tread for what happened to Drew's when his track bar drop bracket tore off, and the subsequent repairs.
viewtopic.php?f=5&t=854&p=9027&hilit=+track+bar#p9027
75DBE
Post by 75DBE »
Ok, sounds like a plan! I am ordering the parts from WH now! Thanks all for the comments, they are much appreciated.
