Rear seat belt question
- akaFrankCastle
I'd planned to go to the yard today and hunt for a set of good used seat belts to put in the back of the Bronco. Was thinking I would pull lap belts from a 70's truck. Wanted to know what the bolt size is on the Bronco rear belts, or if it is a Torx type head. Want to pack in minimal tools, get in and out quick. So, anyone happen to know the bolt size? Danke.
- Jesus_man
Re: Rear seat belt question
1/2" to 5/8" would be my guess but it's been a while since I've messed with mine. - Bitte!
- sbolt19
Take the bolts. They are torx & they will fit the back end.
- akaFrankCastle
Definitely going to need the bolts. All of my hardware is gone. PO stripped the entire backseat and belts out of the truck. Before bolting down a sheet of 1/2 plywood in the back.
- cracker
Look for seatbelts from an early 4runner, the rears work GREAT for EB rears. Long and adjustable!
1-1966 Bronco
1-1967 Bronco
1-1969 Bronco
2-1973 Broncos
And a couple even run.....
1-1967 Bronco
1-1969 Bronco
2-1973 Broncos
