Rear axle seal
Rear axle seal
Post by landshark »
Pulled the rear end out of the bronco tonight to replace the ubolts, plates, centering pin and fix the leak. I pulled the axle shaft out and looks like the seal is ripped/cut off.
I know I will have to pull the bearing and collar off to replace the seal but wanted to know if just turning the seal so the missing part is up and sticking it back in would stop it leaking for the most part? I don't mind ordering new stuff but its kinda a hassle to replace the darn thing as I don't have a press and more $$$$
Colorado75bronc
Re: Rear axle seal
Post by Colorado75bronc »
Nope any tear will leak as the axle turns it flings gear oil, a lot of gear oil
Re: Rear axle seal
Post by landshark »
yup replaced the whole thing today so should be good to go
