4 degree steel shims
- landshark
looking for 4 degree steel shims for the rear leafs, thanks
- Crazyone
Re: 4 degree steel shims
I have zinc 4 degree shims in stock here. Steel are pretty hard to find.
- Gunnibronco
- landshark
What does zinc do for me? Sounds risqué
- Jesus_man
Corrosion resistance. Are they solid zinc or just coated with zinc?
- Crazyone
They are solid zinc. Zinc is softer than steel but works well on heavier vehicles because it tends not to work its way loose which sometimes happens with steel wedges. The zinc holds up well too. The only time I have seen one fail is on a cement truck. That was a little too much weight!
- landshark
might be interested.. i need to re-measure my angles this week I think I have too much pinion angle..
- plumbdoctor
- Crazyone
plumbdoctor wrote:How much for these risqué zinc wedges??
They are 10 bucks each.
