Wiring Harness
75DBE
Wiring Harness
Post by 75DBE »
Now that Corey and I -- well, mostly Corey -- finished installing the new radius arm and C-bushings, the last thing that I seem to be struggling with before I can get this on nthe street is the electrical. Starter and engine turn but I can't get spark to the coil / plugs.
So -- anyone have an extra wiring harness lying around that they wouldn't mind letting go of?
Let me know!
JP.
Re: Wiring Harness
Post by hockeydad4-22 »
I have the infamous "tub-o-wires" which a has all or parts of 3 harnesses. None of them are in good shape or complete, but if you need a switch, connector or particular wire, I might be able to help you. For example, recently a member rooted through and grabbed a complete good fuse box as well as harness section for his tail light wiring.
You are welcome to come dig through the tub and see what I have that might be helpful for you. No charge.
On that note: Folks, If you have parts of or even complete harnesses lying about for our rigs, always tangled up and in the way but you just can not bring yourself to part with them, I will be happy to take them off your hands and add them to the previously mentioned "Tub-O-Wires" which is open and available to all bronco guys who need it at no charge.
valentino
Re: Wiring Harness
Post by valentino »
did you need a stock or efi wiring harness
Colorado75bronc
Re: Wiring Harness
Post by Colorado75bronc »
He needs a stock body harness, atleast the ignition switch section at bare minimum, preferably a complete harness for a 75', or atleast a duraspark ignited truck
