Local CB
- Lobobronco
Re: Local CB
No suggestions, but DO NOT use the shop at Johnson's corner.
Last time I was in there, here is what I was told:
Me: Can I purchase this antennae adapter ($12.00) and return it if it is not the correct one (wasn't sure of my setup).
Owner: Are you kidding me....I'm not here in case you need it...you need to understand I run a business and am not here "in case you might need it".
I politely left without buying the part. Turns out he was steering me way wrong and it was the wrong part! Waste of a drive!
Just my experience and 2 cents.
Matt
Matt
- Entourage
Re: Local CB
That is good to know - I want a CB for trail rides but spending more than $50.00 takes the fun out of it. Think you could mount a CB antenna in the Stock Radio Antenna Hole?
- Rox Crusher
Re: Local CB
For those that do want something better.................
Summit Radio
5 Star Rating: Highly Recommended 3 reviews
(303) 287-3306
7155 E 53rd Pl
Commerce City, CO 80022
Summit Radio
(303) 287-3306
7155 E 53rd Pl
- rtreads
Re: Local CB
You might want to look into a "tuneable" antenna. I have heard that having one, and using a SWR meter (I've heard available @ radio shack $15) to tune it, can make a cheap CB work great. Untuned, a great CB isn't so great.
...I haven't done this yet, but I plan to! ... I dont go with many CB people. The guys I often wheel with like those junky hand held units. I feel like its better to just yell out of the window.
- akaFrankCastle
Re: Local CB
I'm surprised Clay hasn't chimed in on this one yet. I suspect he is a bit of a radio guru. I'd actually had him in mind when I threw out the idea of a tech class specifically oriented towards CBs.
I'm not much of a radio guy myself. I ran a CB in my 97 F150 when I was moving from Alaska to NC about a decade ago. I kept it in the truck for some mild wheeling trips around Fayetteville too. Moved the unit over to my Bronco when I bought it, but it was stolen shortly there after.
- ClayJ
Re: Local CB
Most of my recent radio experience is 2 meter FM (HAM radio). For casual use, I switched from CB to FRS/GMRS about 14 years ago and only get drug back to CB by the Harley guys I ride with (and now you guys).
I do have SWR meters, and at work I have access to a $10k network analyzer that goes way beyond SWR. But I haven't bothered tuning my CB antennas for years. Maybe I should brush up on AM a bit so I can help out when needed.
As for buying a CB, I generally go with a dirt cheap radio so that I don't cry when it's stolen or breaks from the vibration. I personally avoid Midland and Uniden because of past experience, but that's me. I'd avoid radio shack too, but they're just so cheap and plentiful (I get em for $20 on ebay) that I don't care if they only last 4 months. This last one has suprised me and been working great for 3 years now.
If you want a good quality radio and can mount it to dampen some vibration, I would go for a Cobra 29 LTD. I see them on ebay for under $70 but you have to be careful that it's a working unit, not just a parts unit. The cobra 29 has been out in various forms for 20 years so it's well proven. The 29 has auto noise limiting to dampen ignition noise, RF gain to let you pick out the signals you're interested in, and fine tuning to let you hear me on my junk offtuned CB better. You can buy a brand new Cobra 29 for under $100 on amazon.
Whatever CB you get, you'll probably want to buy a better microphone. Stock mics usually provide very poor modulation which results in that muddy sound where you can tell it's a voice and fairly loud, but you just can't understand what's being said.
- akaFrankCastle
Re: Local CB
You like that dime I dropped on you Clay?
Sorry. Didn't mean to put you on the spot.
What's up with the GMRS units? Never really heard of those. Better signal quality and range? How's the price compared to CBs?
Maybe I need to do some research. Hmm
Edit: After doing a quick search online, think I'm going to stick with the CB.
Sorry. Didn't mean to put you on the spot.What's up with the GMRS units? Never really heard of those. Better signal quality and range? How's the price compared to CBs?
- ClayJ
Re: Local CB
FRS stands for Family Radio Service.
GMRS stands for General Mobile Radio Service
CB requires no license - limits transmit power to 4 watts - uses AM - transmits in 26 mhz range
FRS requires no license (like CB) - limits transmit power to 5 watts (1 more than CB) - Uses FM (CB uses AM) - transmits in 460 mhz range
GMS requires an $85 license (no test, just give money) - transmits up to 50 watts - Uses FM - transmits in 460 mhz range
CB supposedly has more ability to transmit when you can't see each other, like on a winding mountain road. FRS and GMRS do best when you can see each other.
AM tends to pick up all sorts of noise, like car ignition, power lines, lightning, or any other electrical noise such as an electric motor. FM is more immune to noise and provides a cleaner sound.
26 mhz tends to follow the contour of the earth where 460 mhz tries to punch through things, that's why CB does better when you can't see each other.
You probably know FRS much more as the little radios that hunters carry in the woods. Every sporting goods store will have a large selection of FRS radios with headsets and even throat mics. I use them when I go skiing or hiking because of how small and convenient they are.
I bought a GMRS license so I could get off of the crowded FRS frequencies and get more power out. I have 10 watt units that we use when travelling by car or bike. We routinely talk 2 or 3 miles apart when driving I-70 and haven't had trouble keeping in touch.
- Kinder
Re: Local CB
I've got a set of GMRS radios as well, I don't remember paying that much, it was more like 20 some when I got my license, but that was a while back.
- akaFrankCastle
Re: Local CB
Turns out I've already got a set of GMRS/FRS radios. Uniden GMR638-2CKs. Bought them back when I was moving to CO from NC. Guess I better learn a bit more about them, and avoid the GMRS channels.
