Zenzone's 1976
Zenzone
Zenzone's 1976
Post by Zenzone »
Hello my name is Zen AKA Zenzone and I live in Arvada. I finally decided I should introduce myself. I am 23 years old and I have had my 1976 bronco since I was 12. My dad and I bought it as a project we could build up together and four wheel while exploring the mountains in Colorado. We have built almost every part on my truck in our garage. When it came to the body work we hired a local guy to do the body repairs and paint it. Unfortunately that was the wrong decision because the guy turned out to be horrible at his job, (Note to self, donΓÇÖt hire 50ΓÇÖs Cruising to work on your rig). So we got our money back and my Dad and I fixed the body on our own as we should have done in the first place. I just recently finished the last body repair, I removed the rust in the rear quarters and welded them shut for a nice smooth look. I just need to paint them to match the rest of the truck.
My bronco has a 5 inch lift, 33 inch ProComp Xterrain tires, 4 barrel truck avenger 470 carb, bullet proof steering linkage, on board air, old sidewinder winch, Corbeau baja RS vinyl seats with four point harness and custom home made front and rear bumpers. Its nothing to extreme, but it is a work in progress as all broncos seem to be. I try to get out and wheel it as often as possible but it competes with the other love in my life that also takes all my time, golf. I am a professional golfer on the mini tours so I spend most of the year on the road playing in golf tournaments. IΓÇÖm excited to meet some fellow bronco guys in the following year.
Re: Zenzone's 1976
Post by akaFrankCastle »
I can't tell you how lucky you are to have had such a great project to work on with your Dad. I'd always wanted to wrench with my dad on my various projects when I was growing up, but things never lined up.
I think we're up to three father-son Broncos now?
Loving the Hickey Sidewinder too. I just might have to see if I can swap the Ramsey 9000 I have in the garage for one of those. icon biggin
71 bass boat
Re: Zenzone's 1976
Post by 71 bass boat »
Nice bronco. What did you think of the think of the bullet proof steering? was it hard to install? has it held up to some abuse?
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Hello akaFrankCastle, I feel lucky to have my Dad who can and will work on the truck with me. He was a diesel mechanic for Caterpillar Heavy Equipment, so he had all the knowledge and tools to do about anything we needed to. Maybe someday we will build a rock crawler together.
The Hickey Sidewinder is nice, strong, reliable and well hidden under the truck. Its not fast but I don't pull myself through the trail so I don't care.
Hey 71 bass boat, I like the bullet proof steering. I believe I have the trail proof strength setup and I believe there was a version that is one step bigger as well (Rock Proof), but the trail proof is pretty beefy. Its not to hard to install. You just have to drill out the knuckles to eliminate the tapper from stock. When you order they will ask you for the measurements in your tie rod and the drag link and then build it to your specs. If I was to do it again I would do the over knuckle setup for extra clearance. I also did a rebuild on the power steering gear box and converted to the saginaw power steering pump. I put a cooler in system that I mounted in front of the radiator. Making all these changes was a world of difference in the driving, it is very tight now and drives great. My system is holding up great and I would do it again.
Thanks for the responses.
airbur
Re: Zenzone's 1976
Post by airbur »
Very nice Bronco! My dad got me started in Bronco-ing back in the late 80s and I've never looked back:) Welcome to the club and hope to meet you and one of our meetings.
Re: Zenzone's 1976
Post by Entourage »
You have done a lot of great upgrades. Really like the Bumpers - WOW! Looking at the photoes, it looks like you definitely have a trail rig but then it almost looks like a show truck paint job - NICE! Keep the pictures coming!
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Thanks Entourage, I do like the paint job. Its not perfect but its good enough for a trail truck. I do need to see if I can find the time this summer to paint the rear fenders blue again. I cant wait to go on a group trail trip this summer.
dsmith01
Re: Zenzone's 1976
Post by dsmith01 »
Great looking Bronco there. Same color I'm planning on
1972 EB - Fuel Injected 351w, 33s, detroit rear
My Personal Website - Home of D-Rock
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Found some old pictures, so I scanned them in. Man I was little then, oh the memories. Enjoy
Re: Zenzone's 1976
Post by Entourage »
Great looking Rims and Tires - you have very good taste! I have had 5 ProComp X-Terrains for months and cannot wait to finally mount them this Spring.
Bitch'nBronco
Re: Zenzone's 1976
Post by Bitch'nBronco »
Nice bronco, I like the on board air
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Entourage, great minds think alike, that tire and wheel combo looks good together. I think you will be happy with them when you have them put on. A good place to store them is your room, they put off a good fragrance. lol I know.
Bitch'nBronco, thanks. I do like the on board air set up. I fit it under the hood in stock form with no body lift, it took a little fab work but we did it. I also have a 4 or 5 gallon tank under the truck that holds extra air. If anyone is interested I know where you can find york's that are 10 stroke, aluminum air tanks and brass airline quick connector dirt cheap.
airbur sorry I missed your post. Thanks. Yep, I blame my dad for getting me addicted to these trucks as well. It's ok I will forgive him.
dsmith01, It is a good color on these old trucks. I'm a sucker for darker blue broncos. Look forward to seeing your truck when its done.
PonyCorral
Re: Zenzone's 1976
Post by PonyCorral »
Zenzone,
BQ here at the Arb! Nice looking truck you have. As it turns out I have one myself. My truck is not quite as nice as yours yet, but its a work in progress...Bring it by sometime I would like to get a closer look. I assume you have more plans with it?
74 Ranger
65 Fastback
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
PonyCorral wrote:Zenzone,
Hey Bobby!! Thats so funny you have a Bronco too. I cant believe we have known each other for so long and didn't know each other were Bronco owners. Such a small world, it took an online forum to find this out. Lets meet up and talk broncos. How is the Arb? Looks like you guys have made some good changes to it. How long have you had your truck? Can't wait to see pictures of it.
PonyCorral
Re: Zenzone's 1976
I have had mine since February...I have wanted one for along time. My truck is under major construction right now but here is a glimpse.
As you can see I have a lot of work to do before mine is road or trail ready.
74 Ranger
65 Fastback
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Bobby, looks like a good truck to start with. I don't see much rust or damage. I like it, what direction are you going with it? Is it going to be a trail truck or a nice restoration?
PonyCorral
Re: Zenzone's 1976
A little of both...I don't want it to be too extreme because I don't know how much it will get used off the highway but, I do want it to look like it can handle the trails if you know what I mean. I am finding out you have to real ly look hard for deals in order to find a clean rust free truck. Because I am doing the work I can afford to buy a cheaper project vehicle!
74 Ranger
65 Fastback
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Bobby, yep I understand your goal. thats kinda like my truck. It is hard to find rust free trucks, like you said if you have the skills to fix it then not a bad place to start. At least you know there is no rust hidden by previous owners. When we started my truck we wanted a truck that was bone stock that way we didnt have to worry about other people's bad work. You should start a build thread if you havent yet. I would like to follow your work.
ManTruck
Re: Zenzone's 1976
Post by ManTruck »
Zen....very nice in all of the aspects, rig, Dad, youth... I am very glad to see all of this. My 19 year old wants to have a Bronco in the worst way but too many irons in the fire right now for him. Like you and your dad we had a few projects together just not a Bronco yet. Keep up the good work and stay the course. If you ever need anything or if i can help you let me know.
Dave
Owned my 1972 since 1985
Canon City, Co
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Dave, thanks. It really is fun to do father son projects, hopefully you and your son are able to do one together soon. I really like your bronco hope to see it in person soon and share ideas.
cobshane
Re: Zenzone's 1976
Post by cobshane »
You got yourself a very sharp looking bronco, love all the add ons. Its great you have held on to it for all these years.
Re: Zenzone's 1976
Nice lookin bronco. I like the color combo of the dark blue and black.
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
Thanks guys for all the nice comments, I appreciate it.
coberlyshane- Thanks, its like a part of my family. I cant see myself ever getting rid of it.
ZOSO- Thanks, I think the dark blue and the black do look good together, I have tried to keep the same theme with a some sky blue accents on unusual parts.
Re: Zenzone's 1976
Im kinda partial to the colors also.
Zenzone
Re: Zenzone's 1976
Post by Zenzone »
ZOSO That is a great looking truck. Once I get the back of my truck painted blue again, our trucks could almost be twins. same wheels and tire size and color. You just have a couple more mods than I do. I'm thinking ARB lockers when I get the money and hook them into my on board air setup. Thanks for the picture.
