Center force clutch
trei75bronco
Center force clutch
Post by trei75bronco »
Looking for a clutch center force 2. Maybe a fly wheel as well. Have a np435, advanced adapters, 302 motor
Re: Center force clutch
Post by landshark »
Dual center force ? Have one that was used with my np435. About 5000 miles on it. What diameter do you need?
trei75bronco
I will need to measure. 10" I think. Do You Have A Flywheel
trei75bronco
How much would you want
Post by landshark »
You need the clutch disk or the pressure plate and clutch disk? I only have the clutch disk and Pretty sure it's 11" or so but will measure tomorrow for you.
Post by landshark »
Only flywheel I have is for a 460.
trei75bronco
Everything. I have a luk in it now and it's no good
Post by akaFrankCastle »
I've got a flywheel you can have.
trei75bronco
Thank you sir. Are you going to the next breakfast? I'm not sure if I can go yet but I'm gonna try
I might make it. Need to figure out if I'll be allowed to drive that far.
But seriously, it's at my house. So, I'll be sure that someone hauls it home for you.
If you need it I have a clutch disk too. Picked it up at the last swap meet so I don't know brand. Guy told me he ran it for just a few hundred miles or so.
