Upper steering shaft
Pulled the steering wheel today to check out something with the wiring. Discovered that the PO stripped most of the threads for the bolt that holds the steering wheel on. Not sure what my options are. I looked around at the major online sellers, didn't see an upper steering shaft replacement. Any suggestions as to where to start on this one?
HorseMan
Re: Upper steering shaft
Post by HorseMan »
I think I have a full length one in the garage. Or it can be cut down a bit, also have steering u joint.
HorseMan, I've PMed you. Classic, not sure why I didn't think of that. I may opt to go that route as well. Thanks!
