brake pedal
brake pedal
Looking for the whole brake pedal arm. Would be a bonus if it had the larger brake pedal pad from a power brake bronco.
Re: brake pedal
Post by Rox Crusher »
ZOSO wrote:Looking for the whole brake pedal arm. Would be a bonus if it had the larger brake pedal pad from a power brake bronco.
I have one that Viper had given me.
I'll set it aside for you.
Re: brake pedal
Sweet!
Sent from my A200 using Tapatalk
Re: brake pedal
The one I have isn't the wide version
If you really want a wide one, here is an option
http://classicbroncos.com/forums/showth ... p?t=249441
I was considering replacing my wide one for a standard one as I sometimes would catch the gas pedal with the side of my boot when applying the brakes.
I just quit being lazy and picked my foot up instead of just trying to pivot on the heel.
Now you know more than ever wanted to about the proximity of the brake and gas pedals on 76/77 Broncos.
I still have this one set aside for you.
Re: brake pedal
Not having the wide version is no big deal. If i have to i'll cut a wide pad out and weld it on. I wont have to worry about it sitting too close to the gas pedal.
I'll get with ya soon to pick that up. Name your price.
Re: brake pedal
Im looking at 2 options.
Im getting parts together for my hydroboost. I want a straight mount. But need it offset over the fender(other side of steering column). Right now I have 2 options.
This bracket
http://www.ebay.com/itm/Early-Bronco-Hy ... 1618127928
Or mounting the brake pedal on the clutch side and bend it back over to the proper pedal position.
Re: brake pedal
Brake pedal is free o charge.
Thanks go to viper
TOOLMAN
Re: brake pedal
Post by TOOLMAN »
