Jesus_man wrote:What is the width? And do you know if a new key can be made or replaced? An upholstery shop could make it look nice again!
Its narrow for an early bronco, i was going to give it some TLC and recover it but decided to do something else so not going to use it. Iam sure you can get another key made if you contact the manufacturer - Its not a tuffy its that other company.
Stroppe'd 1972 Sport, 302, 3 speed with old school Duff floor shifter, T shift Dana 20 with JB Fab twin stick, 4.11 gears with Trac-loc, Lincoln hydroboost, Chevy disc conversion, WH gas lift gate shock kit, 33" Duratrac tires on slots and about 2.5" of lift, Stroppe installed: bumper braces, dual shocks on all four corners, GM power steering, trans cooler mount, auto shift column, rollbar.
Its a Tuffy, I'm sure. It looks exactly like my Tuffy console, I was surprised when Chris said it wasn't Tuffy. I bought mine 15+? years ago. Mine has the circular key design. They may have made changes.
And those locks, circular and/or push button are available locally at decent hardware stores or lock smiths for less than $10. They are very easy to change.
