We put in 1 new wire and one is an existing wire
Both are on the passenger side of the engine harness. Alt is not charging
The old wire is ts one that says "ign relay" and f grounded kills the truck. the new wire is tagged "alt from IG"
Both are "key on hot"
What am I missing? Which side of the relay gets the old wire and where do I connect the new one to the alt
Please hurry, multi meter is reading 11.13 just since starting this post
Where does this wire go?
- hockeydad4-22
- Viperwolf1
Re: Where does this wire go?
The "I" terminal at the alternator needs 12V in run. The "A" terminal should have battery voltage at all times.
- hockeydad4-22
Alt wire to the I terminal as Viper said and.....
CHARGING!!!!!!!
Wiohoo!
Thanks Phil
CHARGING!!!!!!!
Wiohoo!
Thanks Phil
