So...I got started doing my Explorer EFI conversion Saturday by disassembling my motor down to basically the small block. I noticed the timing chain may have excessive slack in it. I turned the motor to #1 TDC and with the chain tight on the driver side, I have approximately 3/4" of play on the opposite side. This motor only has about 40-50K on it. Time for replacement? If so, what to buy? I at least know I don't need to install the fuel pump eccentric if replaced.
Thoughts?
Timing Chain
- TOOLMAN
Timing Chain
- Eck
Re: Timing Chain
I just bought this one (http://www.jegs.com/i/COMP+Cams/249/2138/10002/-1) to replace mine. Also-- so you don't make the same mistake I did-- when eliminating the fuel pump eccentric-- make sure you still attach the bolt and washer to the gear and cam.
- Viperwolf1
Re: Timing Chain
3/4" sounds like it's at it's useful limit. Timing chains are cheap.
- akaFrankCastle
Re: Timing Chain
X2. It's open already. Might as well get another 100k out of the motor by replacing it.
- TOOLMAN
Re: Timing Chain
Measured again last night and I'm at or near the 1/2" play required for replacement. So which do I get? Double roller? True Roller? Something cheap? Billet sprockets? I've never bought one before. I'm surprised (but really not) that this chain only lasted 40-50K. I want to install something that's going to last at least 80K miles!
- Kinder
Re: Timing Chain
It's the chain that wears, so a double roller would likely last longer. Not sure what benefit billet sprockets would add, bling maybe.
