stock carb
- 71Sport
stock carb
Hello all , i think i want to back to the stock motorcraft carb for my stock 302 since most broncos owners swear by them. I bought my bronco with this 350 cfm Holley on it and am looking for a new motorcraft carb. where can i buy one and do i have to change out the jets
- Kinder
Re: stock carb
Pony carburetors offers rebuilt carbs, pretty sure they'll jet them for our altitude. If they need a core you can come grab one of mine.
- 71Sport
Re: stock carb
also my bronco is a 71 but was converted to automatic i currently have an aftermarket cable type kick down lever for my transmission. is the carb for automatics different from manual transmissions.
- Kinder
Re: stock carb
Yes the carbs for an automatic have the correct linkage for the kickdown, you'll also want to get a electric choke, much easier (when setup correctly) in cold conditions.
btw - looks like pony is now champion, they have a core charge of $100 so you'll want to take me up on my core offer.
- 71Sport
Re: stock carb
they probably wont take my holley as a core right ?
- Kinder
horseplay
Re: stock carb
I have a good automatic builder stock heat riser choke it's yours if you want it.
- 71Sport
Re: stock carb
I would take you up on that if I knew how to rebuild one I was hoping to find one just to bolt on
- sykanr0ng
Re: stock carb
A "builder" is exactly what you need for a core.
Unaweep
Re: stock carb
Good info, keep posting please. I have two carbs that I want to get rid of, one Holley and one Motorcraft.
Erik
Erik
horseplay
Re: stock carb
I have a guy here in Evergeen that's one of the best carb guys I've come across. I don't even bother with doing them myself anymore. He's a little slow but he has all the old test gear to check passages and shafts for wear so no headaches on install. His name is Charlie (720) 480-2988 Let him know that Rob from M.I.T. automotive gave you the Number. He will also do a altitude tune for you if it's not your thing.
- mickphatmac
Re: stock carb
I got mine here...looks brand new, plug and play, no Muss, no Fuss. Cheaper than anything I found locally, New, Rebuilt, or otherwise. (I paid to have my 2bbl rebuilt 1st LOCAL)...IT RAN WORSE THAN BEFORE THE REBUILD!!! POS 2bbl!!!
http://www.nationalcarburetors.com/en/
They have Carbs for lots of applications.
Mine was $255 delivered/no core not quite a year ago Edelbrock 500cfm - Couldn't be happier!!!
