Littleton U Pull 2/13
Headed to the salvage yard soon? Keep your eyes peeled for common Bronco modification parts and let people know they are available. Please remember to include the name and location of the yard, as well as WHEN you spotted the parts.
Post by Kinder »
2x 1996 V8 Exploders, both had the desirable GT40 heads still on them, one was complete.
1977 full width D44, high pinion w/ weld on wedges, someone botched a brake removal but the rest was there.
2x trucks w/ NP205s in them, hey Eck!
Several other V8 exploders is various condition.
Re: Littleton U Pull 2/13
Post by Rox Crusher »
Keep your hands off the 5.8 in the 96 Bronco
icon biggin
sykanr0ng
Post by sykanr0ng »
I was about to ask how you botch a brake removal, but then remembered that some people could break an anvil in a sand pile.
Post by Eck »
kinder wrote:2x 1996 V8 Exploders, both had the desirable GT40 heads still on them, one was complete.
I am thinking the NP205 is in my future. And I need a computer out of a 96 Explorer as a backup-- but I think if I went on a yard run on Valentines Day, I may be all alone with my Bronco for a while...
Kirk-- what is your schedule like 2/24 through that week? Wanna go pull a transfer case with me?!
Can I ask why a 205? Other than being strong as hell they suck ass. only a 1.95:1 low range.
Post by Eck »
ZOSO wrote:Can I ask why a 205? Other than being strong as hell they suck ass. only a 1.95:1 low range.
I don't know a lot yet about the best option but am planning on putting in a ZF5 and need an affordable transfer case solution. Was leaning towards the 205 for the strength.
205 is only good with a 203 in front of it. The dana 20 is plenty strong for normal bronco use and about half the weight. I'd rather have the lower gearing.
Post by akaFrankCastle »
Eck wrote:...need an affordable transfer case solution.
I know I read that correctly.
I'm sure fabbing up a crossmember will prove much more economical than shelling out for the ZF-D20 adapter. Initially. Probably much cheaper (time and money wise) to wait until you can afford to do it once. If you don't want to, I'm sure you'll have just as much with the 205 until you move to something else.
atlas time
Im also wondering why no one has bothered to market a lower gear set for the 205 if it's so bullet proof.
ZOSO wrote:atlas time
I'm in the wrong line of work if Atlas is an affordable transfer solution.
akaFrankCastle wrote:Im also wondering why no one has bothered to market a lower gear set for the 205 if it's so bullet proof.
There is ZERO room. There was a company that did make some 3.0 gears. And to get those in the case it required lots and lots of grinding. Leaving little meat to keep the strength.
Here ya go. It includes a new case. So for the price of this you might as well just go atlas.
Forgot the link.
http://www.jbconversions.com/products/lomax205/
Post by Eck »
Exactly why I said affordable b/c I knew someone would jump to atlas.
If it was me I'd just get a new rear output and d20 adaptor. Thats $800-$1000 total. And it fits.
Post by Eck »
Thanks- I haven't done a lot of research yet but that's a definite option. I mean, I just got my rig drivable today so I don't plan to do this anytime too soon.
Post by Kinder »
Rox Crusher wrote:Keep your hands off the 5.8 in the 96 Bronco
icon biggin
There are plenty 5.8 rollers in that yard, I counted at least 5 today.
(Fingers in ears) Lalalalalala!
Kirk, did you see the 1970 F250 Camper Special with the camper on it ?
It was off to the right before you entered.
Post by Kinder »
Why yes I did, had a sign on it that said "runs" I think, looked to be in good condition, 2wd.
sykanr0ng
Post by sykanr0ng »
Also, if those are the same gears I saw, they specifically do not fit the Ford NP205 only passenger drop cases.
You are correct. The Lomax gears are for passenger drop 205's only.
