Wiper arm adjustment?
Stubborn3
Post by Stubborn3 »
Probably a stupid question but is there a way to adjust (shorten) the wiper arm on the passenger side so that the wiper blade doesn't contact the lower windshield trim thus destroying wiperblades? I'm using stock blades so I'm not sure why this is an issue all of a sudden... maybe it's always done it?
Gregg
Re: Wiper arm adjustment?
Post by Gregg »
Good time for a Cherokee wiper arm conversion.
Post by Kinder »
That's odd, the original arms used short, like 12" or less, wipers.
I suspect you've got either non-stock blades or non-stock arms. Or both. The wipers on my rig couldn't hit the bottom of the windshield if they wanted to.
Post by Rox Crusher »
I have the Cherokee conversion and use it with 14" blades.
I take a 1/8" off the blade on the passenger side so it clears the bottom of the windshield gasket
Stubborn3
Post by Stubborn3 »
Seemed odd to me... ordered the wiper arm replacements from WH and they clip right on but it looks like the passenger side arm is a bit longer than the driver side. I'de like to convert to something that lets me run better wiper blades so I'm all ears on this Cherokee swap you speak of
The conversion involves getting a set of wiper arms off of the rear hatch of a jeep Cherokee and then cutting them shorter.
Once you do this, you can use a 13" or 14" blade.
I have a set of arms you can have for 20 bucks.
Pm me if you want them.
Unaweep
Post by Unaweep »
Why the conversion? I have stock wipers and went to O'Reilly's auto parts, they had them in stock for cheap (like $9 each) and even put them on in the parking lot.
Erik
Post by Kinder »
The Cherokee arm swap allow you to run better wiper blades (larger & modern design) and they increase the down pressure of the blade so it cleans better.
Post by akaFrankCastle »
Just as Kinder says, they are an outstanding upgrade; the disc brakes to stock Bronco wiper's drum brakes if you will.
sykanr0ng
Post by sykanr0ng »
Many years ago I had the solid extension on a factory arm come loose, it hit the windshield frame like you are describing, shortly before it got tossed onto the side of the road by the sweep.
