9" rebuild tech day?
Post by akaFrankCastle »
Here's a placeholder and feeler for a tech day. The 9" in Stroppe'd is starting to make stranger sounds. It's always made some noise. Now it's becoming troublesome. So, it's time for a rebuild.
I can host said event at my place in Colorado Springs. We could do some sort of portable, hand held breakfast nourishment.
The catch is I've never rebuilt a 9 and would be looking for a subject matter expert to lead the work.
Anyone interested in leading?
Anyone interested in participating?
March is packed full for me. April is looking quite promising.
Dukietown
Re: 9
Post by Dukietown »
Interested. I'd like to rebuild mine at some point or at least know how to inspect mine to see if it needs rebuilt.
Re: 9
Post by Eck »
I am interested as that is high on my to do list as well.
Re: 9
I'd come just for the handheld breakfast nourishment.
Re: 9" rebuild tech day?
Post by Kinder »
Mmmmm bfast
I don't know how long the rebuild process takes, but I was thinking this could be a max participation event. Maybe get 2-3 axles together and have groups working on each while one overlord, er, instructor talks us through the process while a large drum is pounded in the background.
Perhaps we can get someone to chime in on what all needs to be purchased to make this happen. I'd like to rebuild everything on my axle, minus the brakes. And I'm certain I will be purchasing new gears.
Post by Kinder »
2-3 no way, 1-2 maybe, 1 for sure. Especially if it's a complete rebuild. Stock rebuild or? I can post up what you need.
Re: 9
You'd need a rebuild kit, gears if you're doing them, and wheel bearings. It'd be worth dropping the center section to verify what size carrier bearings you've got. Mine are larger than stock and it caused some consternation and a parts run.
horseplay
Re: 9
Post by horseplay »
Tools to consider torque Wrench, dial indicator & magnetic stand ,spanner Wrench for pre-load ,slide hammer with hub adapter if the axles haven't been out before. Maybe a extra crush sleeve just in case. A torque multiplier is nice for setting the crush sleeve.
kinder wrote:2-3 no way, 1-2 maybe, 1 for sure. Especially if it's a complete rebuild. Stock rebuild or? I can post up what you need.
I'm looking at a stock rebuild. It is a 4.11 trac lock.
Post by Kinder »
I've got all the tools necessary for the rebuild. Are you going to rebuild the trac lock?
Re: 9
Post by Viperwolf1 »
Hopefully it's a 4 pinion trac lock. The 2 pinion ones tend to break. I can remember mine, Drew's, Shawn's.
I'm thinking its a 2 pinion. I've read the only 4 pinion ones came with 31 spline axles. And it would be my luck to have the inferior of the two options.
Re: 9
They can be found in 28 spline flavor too. '76-'77 Broncos had the 4-pinion.
Re: 9
Dont waste your time with a regular crush sleeve. Buy the shimmable pack that replaces the crush sleeve. Under hard use and acceleration the crush sleeves can collapse.
Dirtheadz
Re: 9
Post by Dirtheadz »
Justin wrote:I'd come just for the handheld breakfast nourishment.
x2 on the breakfast icon biggin ... I think 3-4 is achievable, especially if guys are just bringing their 3rd member, all ready removed from their housing.
Re: 9
Depends on who attends. If we get several folks that know how to do it, then 3-4 is doable. Doing the 9" and D44 on my rig to most of an afternoon with Kinder, Crawlercreations, and Viper present.
Unaweep
Re: 9
Post by Unaweep »
I'd love to attend this, I would combine it with a work trip if the date works out.
I never worked on any differentials before, although I destroyed a couple of them :)
Erik
Freewheeler
Re: 9
Post by Freewheeler »
I'd love to attend as well, since I plan on replacing my 3.50 Trac-Loc with a Detroit and different gears in the near-ish future.
1978 Bronco w/Free Wheeling Package - all original from factory: 400/C6/NP205, 9" rear/high pinion D44, not to mention the tri-color stripes and plaid seats. WH 4ΓÇ¥ lift, 35ΓÇÖs, WH Hydroboost, rear disc kit, chrome shafts, 4.11ΓÇÖs, DetroitΓÇÖs f/r, 3G alt, Protofab cage and rear bumper, restored interior and other stuff.
Re: 9
The 9in is the easiest to set-up for sure. No need to press anything apart to change shim packs.
av8nmech
Re: 9
Post by av8nmech »
I'm in, I'll pull my carrier out this weekend to figure out what size bearings I need. Where's the best place you guys have found to get a rebuild kit?
Can we get Chorizo buritos? Those are the best.
av8nmech wrote:I'm in, I'll pull my carrier out this weekend to figure out what size bearings I need. Where's the best place you guys have found to get a rebuild kit?
I ordered my rebuild kit from Wildhorses. Seems pretty legit but I'm obviously ignorant on these things or I'd have already rebuilt it myself.
I don't remember where we got burritos from last time in the Springs but I don't think chorizo will be a problem.
Post by Kinder »
Most kits are good quality, I've used G2 from 4wheelparts, Yukon & USA standard gear.
Re: 9
Post by landshark »
kinder wrote:Most kits are good quality, I've used G2 from 4wheelparts, Yukon & USA standard gear.
might want to watch the ring gear bolts. The Yukon kit that was used the rear of my 69 ring gear bolts bottomed out on the ARB carrier. not sure why mine would have been different from thousands of others.. but I don't discount the PO either..
Benwehmann
Re: 9
Post by Benwehmann »
I just moved to Denver about 6 months ago and just found this group. I have a 1973 Bronco but it is still in Wisconsin in my storage unit. I have never rebuilt a 9" but would love to come if you are still going to make this happen.
Benwehmann wrote:I just moved to Denver about 6 months ago and just found this group. I have a 1973 Bronco but it is still in Wisconsin in my storage unit. I have never rebuilt a 9" but would love to come if you are still going to make this happen.
We're definitely still interested in making it happen. We're just awaiting a volunteer to lead the rebuild. I'm afraid 20 guys huddled around my laptop, watching a YouTube video just isn't going to cut it on this one.
Once we do find that fearless leader, we'll get things formalized and push an email out to all members.
In the meantime, where are the pictures of this Cheesehead Bronco? :)
Post by Eck »
I'll be looking to do this soon. Anyone interested in reviving this thread, leading this tech build day?
colby45
Re: 9
Post by colby45 »
I'd be interested in participating to learn the process, but I have never done a rebuild before.
Sally
'66 Halfcab
Re: 9
Post by hockeydad4-22 »
The last one we did was up in Greeley at Addicted Offroad and it was pretty awesome! I would be very interested in attending another
sykanr0ng
Re: 9
Post by sykanr0ng »
hockeydad4-22 wrote:The last one we did was up in Greeley at Addicted Offroad and it was pretty awesome! I would be very interested in attending another
I should have known better than to Google "addicted" and "Greeley" together.
