C4 woes....
- ZOSO
- Moderator
C4 woes....
Ok just a couple questions. Parking pawl. Is it possible for it to try and engage if the "return spring" is weak or missing. All while making a pretty hard left turn? Im trying to find this random "clicking" noise coming from the drivetrain. It is not the fan hitting the shroud. It's coming from the trans/tcase area.
cravenbronco
Re: C4 woes....
ZOSO wrote:Ok just a couple questions. Parking pawl. Is it possible for it to try and engage if the "return spring" is weak or missing. All while making a pretty hard left turn? Im trying to find this random "clicking" noise coming from the drivetrain. It is not the fan hitting the shroud. It's coming from the trans/tcase area.
X2 I have been hearing the same on Big Blue and like you say its coming from my trans/tcase area.
I know its not my tcase cause it was just rebuilt.
- Viperwolf1
Re: C4 woes....
Your spring is there and not broken. Make sure the linkage is adjusted correctly. Still with incorrect adjustment you could only have that problem in reverse. I'd look closely at the CV joint.
- ZOSO
- Moderator
Re: C4 woes....
I'll pull the rear shaft out. It just started recently and is only when I make a hard left turn. I'll look more into it today after work and see if I can record the sound.
