The reason I know its out of camber is every tire I put on that front left (driver side) the outside edge of the tread wears faster that the rest. Regardless of axle straightness and in light of my upcoming trip I am thinking I can remove 1 degree + from the front driver and .5 degrees negative out of the passenger side to get somewhere in the ballpark for even wear.
Bronco currently drives great - even with the uneven tire wear before I stuck the camber shim in.
Am I thinking about this correctly? I have read .5 degree positive camber is good on Broncos with D44, 3.5" lift and running 35" BFG's - however i wasn't sure that was total or each side?
So to recap - before alignment I installed spindle shim on driver side knowing there was too much positve camber. Did nothing on the passenger side. Results are below.
