Eck's Ford 9" rebuild
Post by Eck »
I am going to start ordering parts and start working on the rebuild of my 9". Thought it might be easier to start a separate topic and thread to post the progress. I am starting with a 66-75 Big Bearing housing with 11" Brakes.
Here is my shopping list and I do have a couple of questions:
BOUGHT already - Wild Horses 31 spine axles (part number 8602)
Yukon Ring and Pinion 4.56 gears (part number YG F9-456)
ARB RD119 differential (4.56/ 31 spline)
MASTER Install kit: Question- There are two different ones available. One for 3.06in. Bore Case and one for 2.96in. Bore Case. How do I know which one to purchase?
ARB twin compressor (part CKMTA12)
Brake rebuild:
Drum Hardware Kit (Oreillys part H7144)
Brake Shoes (Oreillys part BB 283)
Brake Drums (Oreillys part 2611D6S)
Anything that I am missing or need to consider?
Re: Eck's Ford 9" rebuild
Might be a good time to also replace your e-brake cables if they're non-functional. Not hard to do later, but as long as you've got it apart....
Post by Eck »
Justin wrote:Might be a good time to also replace your e-brake cables if they're non-functional. Not hard to do later, but as long as you've got it apart....
Changed those last year. E-Brake is functional!
Add a shim-able crush sleeve to the list. That way you never have to worry about the thing collapsing on you under high torque loads.
Only way to tell the bore case size is to pull out 3rd member and measure the carrier bearing bore.
Post by Digger »
ZOSO wrote:Add a shim-able crush sleeve to the list. That way you never have to worry about the thing collapsing on you under high torque loads.
After what I did to my truck this weekend, 2x on the crush sleeve eliminator kit.
Post by Eck »
Do you guys have a link to one so I have an idea what it is?
The install kit I was looking at getting is: http://www.4wheelparts.com/Drivetrain-D ... G/235-2011
They have the same one for the smaller bore once I figure out which one I have...
I just put one in mine since I had to do the pinion seal. And your post is what made me think about it also. At $30+ most people dont want to spend the money but its well worth it.
This is for an 8.8 but you get the idea.
http://www.jegs.com/i/Yukon+Gear/807/SKCSF8.8/10002/-1
Post by Eck »
ZOSO wrote:This is for an 8.8 but you get the idea.
Thanks-- once I looked at crush sleeve eliminator, it came up. Will add to the list...
sykanr0ng
Post by sykanr0ng »
Oh noes, he put that on you.
Here comes the frame off rebuild.
Post by Eck »
Is there a way to measure the size suspension lift I have? I just want to double check before I start ordering replacement parts.
phyler
CCB Admin
Post by phyler »
Measure between the frame and the axle. Stock was 7" upfront and 8" in the rear.
OG
Post by Eck »
Both front and rear measure out at 9". The rear leafs are 8 leaf and I don't see any blocks or anything. Does this mean I have a 2" suspension lift up front and 1" added with an add a leaf in the rear?
phyler
CCB Admin
Post by phyler »
Most likely. I would guess there is the possibility that the front was 2.5 at some point.
OG
Post by Eck »
phyler wrote:Most likely. I would guess there is the possibility that the front was 2.5 at some point.
Probably so. I have since added a 351W, power steering, and EFI, so it wouldn't surprise me if the added weight has compressed it by a half inch.
So my next question is what to order for the suspension parts. I think I will go ahead with 3.5" lift springs for the front unless the extra inch would cause me to have to change a bunch of other stuff? I already have to change my driveshafts when I install the ZF5 so that isn't a problem. Does that mean that in order to keep the Bronco level, I would then go with the 2.5" rear lift? I am planning on going with the WH 11 spring kit but they offer it in 2.5, 3.5, etc.
phyler
CCB Admin
Post by phyler »
I would check brake lines (from the frame to the axle and emergency cables). Those are usually the main issues.
I found when I did my 2.5" lift that everything stayed pretty level. Granted, I have K-Bar-S front springs that haven't sagged at all. :) I think if you go with the 3.5" up front, you will find that the front will be slightly higher. Even after it settles, I don't know if you will be level. Hopefully someone else can chime in on that. I doubt you will see .5" of sag (assuming you have enough weight to sag it .5" to begin with, though I'm not sure you do). I think if you match the front and rear, you might end up with .25" rake but that would be hardly noticeable.
I've got my eyes set on the WH suspension with Bilstien shocks to replace mine, but that's after the engine swap and the body panel replacement projects. :)
OG
sykanr0ng
Post by sykanr0ng »
That and you have a winch don't you?
In PM's with DirtDonk over on CB he said most likely that will sag the front of newer springs about an inch.
And take away some of the softer ride of the newer suspension.
Post by Eck »
Yah, have a heavy Warn Belleview with a pretty stout homemade prerunner style front bumper.
sykanr0ng
Re: Eck's Ford 9
Post by sykanr0ng »
Eck wrote:Yah, have a heavy Warn Belleview with a pretty stout homemade prerunner style front bumper.
So about the same weight as the Warn 8274 I asked him about.
Post by Eck »
I am looking to place my order for the Ring and Pinion and want to make sure I get the correct one.
Going with ARB 31 spline 4.56 gears.
I was looking at Yukon YG F9-456 ($250) on Summit Racing. Is this the correct ring and pinion?
Does anyone have any comments or suggestions on a brand or something that may work just as well at a better price?
Post by Eck »
Eck wrote:I am looking to place my order for the Ring and Pinion and want to make sure I get the correct one.
Looks like some people over on CB have had luck with Motive Gear? Those are about $100 cheaper than Yukon. Couple people say the Richmond gears are loud.
Post by Digger »
http://www.amazon.com/Yukon-F9-456-Performance-Gear-Differential/dp/B0078UBZPE/ref=sr_1_6?ie=UTF8&qid=1441825495&sr=8-6&keywords=ford+9+inch+gears
$238 and free shipping with PRIME
And yes, that is the right gears.
Don't forget to buy an install kit with the gears.
TOOLMAN
Post by TOOLMAN »
I'm planning on rebuilding the chunk while I install an ARB with 31 spline axles. So, which size carrier bearings am I looking for 2.9, 3.0, or 3.25? I would assume it's the smallest, but wasn't sure if that changes due to the switch from 28 to 31 spline axles.
The outer diameter of the bearing stays the same, so it'll be whatever your stock one is. If it's early bronco, it's likely the smaller ones.
Post by Kinder »
31 spline axles won't fit the smaller bearing carrier, do some measuring and make sure you have the med or larger bearing sized carrier.
Edit: Justin, not certain, but I think they do change outer & inner. I say this because I couldn't stuff 31 spline axles into my stock 28 spline carrier when I upgraded my axles years ago. Might be a year thing, my '73 had the stock rear housing, axles & carrier in it.
No, I think you're right. I'm used to carriers for 31 or 35 spline stuff.
Post by Eck »
Kirk- WH sells a tapered 31 spline for use in the small bearing housing. I believe that's what he is using.
http://www.wildhorses4x4.com/product/Ex ... _10in_Drum
Jason- I believe it's based on the third member. Aftermarket heavy duty third members increased the size of the carrier bearings. I measured the one that came out of the big bearing housing in rebuilding and it was the smallest one 2.89 I think.
Post by Eck »
Got the last delivery of parts for the rebuild today. Picked up the ARB stuff on Tuesday. Bench full of former $100 bills.
Also spent about 3 hours cutting, grinding, and sanding on the axle tube. Whoever worked on this axle previously was the worst welder (and I should know what a bad welder looks like). Still need to take a wire wheel to it and then I can look at getting the new spring perches and shock mounts fitted and welded on. Then on to paint.
