So I'm running full width 44 (dual piston) and doing Chevy calipers on my rear 60. Currently running '76 (?) camper special M/C, that leaks like a mofo, and they brakes were sh!ty to say the least with my rear drums. So looking for some input on MC's. Couple things:
Yes they were bleed & bench bleed the MC... Stock H block with no intention of installing a new proportioning or res valves... Vacuum booster, with intent to do hydro later... I have used the search...
My axles are '78 F250... So why should I not just run a '78 dual piston MC? Should I entertain a corvette MC? Keg is empty, Should I ponder this over more beer?
Curb weight of a Corvette is around 3200 depending on the model, engine, etc.
My super duty weighs 7800.
Broncos were around 3500-ish I think. 3/4 ton axles. 37" tires and steel wheels with bead locks. Cage. Tools. Sliders. Bumpers.
You see where I'm going. Same thing we talked about on the phone. I think you're making the right call.
Stroppe'd 1972 Sport, 302, 3 speed with old school Duff floor shifter, T shift Dana 20 with JB Fab twin stick, 4.11 gears with Trac-loc, Lincoln hydroboost, Chevy disc conversion, WH gas lift gate shock kit, 33" Duratrac tires on slots and about 2.5" of lift, Stroppe installed: bumper braces, dual shocks on all four corners, GM power steering, trans cooler mount, auto shift column, rollbar.
