Pair of 9" axle shafts off my '71. 28 spline, small bearing for 10" brakes. I think the passenger side is OEM while driver's is newer aftermarket (spun a bearing on the original back in the late '90s). New Timkin bearings pressed on 2 winters ago...probably 6000 miles on them. Haven't been run through water yet (edit: After thinking about it, they've been through water twice: at French Creek last summer and at Caribou this fall. Sorry for the possible misrepresentation.). All you would need is the retainer plates. - $150
Would still be running them but I have to go to 31 spline axles to accommodate the ARB.
9" Axle Shafts
- TOOLMAN
9" Axle Shafts
