Cut Sheet Metal
Cut Sheet Metal
Post by Entourage »
My rockers are rough on the bottom and really just need to weld in a new panel. I need 2 piece of sheet metal 4" x 40" - is there a place open on Saturday to get this kind of stuff?
Re: Cut Sheet Metal
Post by Entourage »
Killa - that is right by my house too! Thanks Dan.
Re: Cut Sheet Metal
just cut them off. you dont need rockers. all they do is collect dirt and mud. rust out and get smashed when wheelin.
Re: Cut Sheet Metal
Post by Entourage »
Cutting the rockers was totally the plan then got new uncut fenders and the whole build changed - crazy I know. A month ago I was fo sho going to cut it all off.
Re: Cut Sheet Metal
Still not too late. You havent painted it yet.
PonyCorral
Re: Cut Sheet Metal
Post by PonyCorral »
I saw some cool rocker covers check these out, they are from West Coast Broncos.
http://www.wcb4x4.com/mm5/merchant.mvc? ... y_Code=EXT
74 Ranger
65 Fastback
Re: Cut Sheet Metal
Post by Entourage »
Those are Bad A, I think Dnewman has those on his Bronco.
PonyCorral
Re: Cut Sheet Metal
He does and they are bad a**! He said that this was the first bronco he had with good rockers and wanted to keep them that way. WCB uses rattle cans to paint them so that they are easy to touch up.
74 Ranger
65 Fastback
Re: Cut Sheet Metal
You know they're no joke when your rockers weigh 63 lbs. I'm torn between cutting my rockers (rust) and doing something like this. I'd cut them in a heartbeat, but kind of want to maintain use of my aux tank.
Re: Cut Sheet Metal
Justin wrote:You know they're no joke when your rockers weigh 63 lbs. I'm torn between cutting my rockers (rust) and doing something like this. I'd cut them in a heartbeat, but kind of want to maintain use of my aux tank.
You still can use the aux tank. build a skid plate that wraps around the side. My dad build one for the 74. Good thing too cause on spring creek we put it to the test and used it to slide along a rock.
Re: Cut Sheet Metal
I've been thinking about something like that. Maybe doing a regular 2x6 slider on the passenger's side and building either a 2x6 with an additional plate to cover the tank or a triangular slider w/more space for compressed air.
PonyCorral
Re: Cut Sheet Metal
Come on by, I just put a new one on the DS...It makes a helluva difference in the look! Since your gonna run uncut I think you will like them with or with out the covers.
74 Ranger
65 Fastback
Re: Cut Sheet Metal
Post by Entourage »
There has been chats off and on over the last few months about rockers and I know that CMCDowell wanted to build some from the 2 x 6 square tubing as well. That would be an awesome tech class. I remember Dan chimed in stating he wanted to use his for air tanks.
Re: Cut Sheet Metal
Post by Entourage »
I called Commercial Sheet Metal in Denver - they are cutting me 2 new rockers 4" x 40" for $5.00 Each and ready this afternoon. I hope they will do a great job and become another resource for the club.
