Wish list of 66 parts I need for my resto
- Gunnibronco
In search of the following items (I'll be adding/modifying this list as I go) This list is also as much for my reference, to keep a neat list of what I'm looking for:
Rear seat belts
Washer bag cap
Lug wrench & jack tool tie down brackets & hardware
Light switch
?Plate, bolt & wing nut for spare tire carrier
Gas Cap
If you have any of these please contact me, or post up in the thread.
Thank you.
Rear seat belts
Washer bag cap
Light switch
Gas Cap
Thank you.
- akaFrankCastle
Re: Wish list of 66 parts I need for my resto
Pretty sure Don has visors.
I have a shift lever somewhere. For reference, you can use the shift lever from a '60s F series too. So, don't let anyone try to sell you a "one year only Bronco part" for that.
- akaFrankCastle
I'll put them in your pile.
JGZ
Is the shift linkage 66 specific?
- Gunnibronco
Zac,
I was starting to think the 66 F100s had the same one, but was struggling to find a decent pic.
Can you run me a tab for 66 parts? LOL.
JGZ,
I'm not sure, I *think* the 8 cylinder linkage will fit, only because I didn't find 2 options at places like Toms, WH, BCB, etc.
JGZ,
JGZ
I have a couple sets of the linkage you can look at to see if it's what you need.
- Gunnibronco
Wish list adjusted based on current belief of how this truck was built.
- Eck
Do you need the Tcase shift linkage? Or the shifter? Mine had a Hurst handle on it but I have no idea if that meant the linkage and actual shifter was aftermarket. I just twin sticked mine so your welcome to it...
- Gunnibronco
The shift handle itself. 66 is different than the other T-shift D20 shifters. Mine was cut short to clear the NP435 shifter.
Its very low on the priority list. A piece of 3/8" rod will restore it to the original height.
- Gunnibronco
Update bump.
- Gunnibronco
Update & swap meet bump!
